HELP!!!!!
Old Apr 19, 2013 | 10:07 PM
fordman67's Avatar
fordman67
if it set a light I sure would think you could look in codes stored history and see what it WAS on for.
did they check any other values for possible clues to the issue? ipr,icp,temp,anything? of course If they did they prob wouldnt say anything as they didnt say so I guess.
Old Apr 19, 2013 | 10:46 PM
johnnyggreen's Avatar
johnnyggreen
Yea they didn't do any test they wouldn't even tell me what was wrong good thing I didn't pay em right
Old Apr 19, 2013 | 10:53 PM
stevorino's Avatar
stevorino
I'm betting bad IDM. Mine did something similar. It would miss like the engine would turn on and off at random times and it didn't have any rhyme or reason to it. One thing that seemed to make a difference was actually moving the IDM. Sometimes I would unbolt it from the fender, knock on it with a screwdriver or something, and then reinstall it and it would run again. I had a mechanic that let me try one off another truck he had. Worked like a charm.
Old Apr 20, 2013 | 08:30 AM
fordpride's Avatar
fordpride
If the scanner wasn't communicating with the truck they either don't have a scanner that wow with a obs or the OBDII port isn't getting power.
Check the fuse for the cig. lighter. It powers the OBDII port.
If the light was set then you have a code
Old Apr 20, 2013 | 10:31 AM
stevorino's Avatar
stevorino
The code issue seems fishy to me also, but if the CE light was coming on, I would think the garage isn't using the correct scanner. I would also take the valve covers off and actually check the inside of the connectors, because sometimes you can't see the damage from the outside. My IDM did not have any water in it, but it was bad. I know these are frustrating problems because changing out these parts is a lot of money and every time you try something it may or may not fix it. I was fortunate to have a mechanic who wanted to be sure of the problem before he threw parts at it.
Old Apr 20, 2013 | 02:24 PM
johnnyggreen
I changed the valve cover gaskets and harnesses all fuses are good I'm thinking I may just change the idm when I get paid around the first if I'm able to I'm gonna video what's it doin and see if any of you guys have had this problem
Old Apr 20, 2013 | 08:39 PM
stevorino's Avatar
stevorino
As it happens, I was driving today and my truck just died while I was at a light. It would not start after cranking it and it appears that my brand new IDM took a dump. It is the exact same symptoms I had last time. I finally got it started after pushing it off the road but it runs at most for 15 seconds before the WTS light comes on while it's running and and then it coughs and dies. I put the SCMT on it and it says "too many codes to read" which is what it did last time. I'm hoping its just another bad idm and not that my truck is eating these things. I do recommend doing the video. I did that last time, maybe yours will look like what mine did/is doing.
Crewcab Turbo
Feb 6, 2012 09:02 AM
mark460
Nov 14, 2011 09:20 AM
jtwalker
Sep 8, 2010 11:26 AM
ihateminimumwage
Sep 15, 2006 11:33 PM
Kijutsu
1997 - 2003 F150
Aug 12, 2006 06:32 PM
