Most common rust areas?
Old Mar 26, 2013 | 10:45 PM
GBuckert's Avatar
GBuckert
So while I'm waiting on tying up the last few ends before listing my pickup for sell I've decided to find out if it's truly rust free.
I thought the cab corners and wheel wells would be the most likely places for rust and yet they both felt as smooth as the painted surface on the outside of the body. Any hidden body parts to check?
The frame has a good scattering of surface rust everywhere but it seems pretty solid. I just read that the crossmembers get weak so I'll check them when I swap the driveshaft out. Any particular pockets to check out on the frame as being the first to go?
Thanks in advance for the help.
Old Mar 26, 2013 | 10:47 PM
str8sixman's Avatar
str8sixman
ive seen some by front frame horns, where the radius arms mount to the frame, and behind the rear springs. hows your core support? i know here in pa even the radios rust out haha
Old Mar 27, 2013 | 01:00 AM
Puddy's Avatar
Puddy
Bed supports, and rad saddle. And of course the fenders.
Old Mar 27, 2013 | 03:58 AM
SideWinder4.9l's Avatar
SideWinder4.9l
Wheel arch and quarter panels are the first to go, usually...
The lower portion of the front fenders usually eat through quick also.
And make sure to check the Core Support section (Where the Radiator sits)..
They tend to rot out from the factory, essentially...
Old Mar 27, 2013 | 11:13 AM
Freightrain's Avatar
Freightrain
Being Wyoming, it is likely pretty dry and not as bad as a OH/PA truck would be.
It sounds pretty nice, if the rust hasn't blown through anywhere by now it should be good for a few more years.
My '89 came from NC, the frame was still completely BLACK and not as much as a scratch of surface rust yet. Not bad for a 24 yr old truck. It turns heads in Ohio, as I don't think there is one left here that isn't rotted to the ground by now. I've oil sprayed it for 3 yrs now and still good and clean(just oily now LOL).
Old Mar 27, 2013 | 04:55 PM
Diesel_Brad's Avatar
Diesel_Brad
Radiator supports are the FIRST thing to go.
my lighting was(what I thought to be) rust free. but the rad support was rotten at the mount area. EVERYTHING else was SPOTLESS.
The rear spring hangers and shackles are know to be troublesome as well.
Check the bottom seams of your doors and tailgate.
Old Mar 28, 2013 | 08:54 AM
stewart89's Avatar
stewart89
I would check the bottom of the doors and the cab floor under the rubber/carpet,
Old Mar 28, 2013 | 09:10 AM
blue924.9's Avatar
blue924.9
if you would like to make it rust free for a potential buyer, take your time and check everywhere on the truck
Old Mar 28, 2013 | 10:39 AM
Jarryd's Avatar
Jarryd
The only place I found on mine was an exhaust hanger. Everything else was clean.
Old Apr 1, 2013 | 08:45 AM
GBuckert's Avatar
GBuckert
Well my exhaust had many holes rusted in it, but it's been replaced.
Looks like there is a bit starting above the fenderwells and enough on one shackle to cause the paint to peel. I don't have any shots of the floor, but it was clean when we pulled back the carpet to swap transfer cases.
Other places that I've missed?
Old Apr 2, 2013 | 04:29 AM
Diesel_Brad
That is Not rust free to me with the wheel wells blistering like that. But everything else appears to be pretty clean other than the frame having light surface rust.( I would show all pics you just posted)
Old Apr 2, 2013 | 11:46 AM
dixie460's Avatar
dixie460
My Southern 96 SuperCab has surface rust on the frame, and rad support. Top of the cab had surface rust, and there is currently a spot at the top of the pass. door jamb where 2 sections of metal meet that is rusted pretty bad. Will fix that next weekend. Other than that, just a mysterious rust hole in the firewall behind the defroster duct, I was wondering where my cab water leak was coming from and found that hole. Of course, then I checked the front floorboards and they have light rust from the water that the jute padding absorbed and held against the metal for however long. The rust hole in the firewall is waiting for a nice weekend when I can pull the complete dash, ducting and cowl panels off and cut out the bad section. I'll weld a new piece of sheet metal in rather than dealing with the rotted stuff. Truck has been in Florida it's entire life to my knowledge.
Old Apr 2, 2013 | 12:00 PM
ravens fan's Avatar
ravens fan
Very clean truck GBukert! Even the southern truck will have some surface rust on the frame and a few other places, my brothers truck spent its whole life in Texas until last year and has some. we are now gonna give it a nice coat of POR and see how long it takes for PA salt to do its toll
brianf40
Jul 8, 2016 01:22 PM
OliveDrab76
Dec 24, 2013 01:54 PM
dans 51 f2
Nov 6, 2010 06:37 AM
tyson1992
Apr 28, 2004 09:28 PM
carfreak113
1978 - 1996 Big Bronco
Apr 20, 2004 09:52 AM
