Axle Identification
Old Mar 26, 2013 | 08:48 PM
GaryLP's Avatar
GaryLP
Axle Identification
Hi, I have a '78 F-150, 4 x 2, was a 351 M now a 460. The rear axle is coded 15 J on the door. On the axle it says 3.25. What I need to know is it a 31 spline or is it a 28 spline axle? I am looking to buy a 3.50 locker rear axle and I am going to look at a 31 spline one tomorrow. The guy wants $ 250.00 do you guys think that is a fair price? They seem a little scarce around here. I am in Nebraska.
Old Mar 26, 2013 | 09:04 PM
redroad's Avatar
redroad
does the rear axle look like this Ford 9"
or like this Dana 60 rear end
Old Mar 26, 2013 | 09:07 PM
GaryLP's Avatar
GaryLP
It is a 9 inch Ford
Old Mar 26, 2013 | 09:15 PM
redroad's Avatar
redroad
Originally Posted by GaryLP
It is a 9 inch Ford
You'll need the numbers on the tag of rear of diff to ID spline count
Old Mar 26, 2013 | 09:39 PM
GaryLP's Avatar
GaryLP
I have the rear axle tag in my hands. There are 2 lines. On the bottom is says 3.25, space , then 9, space then 384 D. Top line says W D M, space, then 8[or B] A 2, space then 7 F A
Old Mar 26, 2013 | 09:42 PM
redroad's Avatar
redroad
See here Ford Rear Axle Assembly Identification - Page 04 - FORDification.com
Old Mar 26, 2013 | 09:54 PM
GaryLP's Avatar
GaryLP
According to that it is a 3.50, 31 spline axle. But the 15 J on the door says it is a 3.25 axle. I am really confused now.
Old Mar 26, 2013 | 10:14 PM
redroad's Avatar
redroad
The axle was probably changed out .. What size tires are you running?
Old Mar 26, 2013 | 10:21 PM
GaryLP's Avatar
GaryLP
I bought the truck from the original owner. He says they have never changed anything. As far as tires. 2.55 X 18 on aluminum wheels.
Old Mar 26, 2013 | 10:44 PM
redroad's Avatar
redroad
So your running 33" tall tires? Your missing 1 number 2.55 x ??? x 18
Old Mar 26, 2013 | 11:10 PM
redroad's Avatar
redroad
Here's another reference that should help clear things up 31 spline
https://www.ford-trucks.com/forums/1...l#post10398311 Need to be sure you don't run to tall a tire with those gears though
Old Mar 27, 2013 | 04:28 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
I have the rear axle tag in my hands. Top line says W D M space 8 [or B]A2 then 7FA
No such thing as WDM 8. The AXLE code prefix is always followed by a letter suffix. Then there could be a number, another letter, or a letter and a number. So what you have is:
WDM BA2 = Ford 9" Rear Axle / 3.50-1 / No Limited Slip / D6TZ-4234-A = 31 spline R/L axleshafts.
7FA = Assembled the 1st week (A) of June (F), 1977 (7).
Warranty Plate AXLE code 15J: 15 = Ford 9" Rear Axle / 3.25-1 / No Limited Slip // J = Power Steering.
Compare the VIN on the registration to the VIN on the Warranty Plate to see if they match.
People replaced damaged left doors with used doors. 99.9% of the time, they failed to install the original Warranty Plate on the replaced door.
If the VIN's do not match, the 15J AXLE code is wrong. If the VIN's do match, the rear axle was swapped.
Old Mar 27, 2013 | 09:54 AM
mikeo0o0o0's Avatar
mikeo0o0o0
What's confusing me about this is the OP says that the axle tag says 3.25 also, not just the warranty plate (15J). WDM-BA2 does cross to a 3.50 ratio, but why would the same tag show 3.25?
I'm wondering if the tag has been misread and the code is actually WDM-BY2, that would cross to a 3.25 ratio.
Kind of a moot point though. Both axles use parts list #88, so both will have 31 spline axles.
Old Mar 27, 2013 | 11:26 AM
NumberDummy
WDM-BA2 & WDM-BY2 = D6TZ-4234-A .. 31 Spline Axleshaft.
Old Mar 27, 2013 | 06:33 PM
GaryLP's Avatar
GaryLP
Ok, Went to the body shop and checked the door tag against the VIN on the registration. They are the same. Called the guy who sold me the truck. He bought it new, he says he has never worked on the rear end except for brakes. The tires are 255 x 45 x 18 on the rear and 235 x 45 x 18 on the front. Love my truck...... why does my tag on the rear end say 3.25 yet definately says WDM BA 2 on the top line?
