390 Engine Compression?
Old Jun 3, 2003 | 02:48 PM
gktbay's Avatar
gktbay
Question 390 Engine Compression?
Can someone help?
Using '68 390 2v heads --- along with forged flat top pistons (.030) / valve reliefs.
Stock crank and rods ... any calculators out there for compression ratio?
Old Jun 3, 2003 | 03:59 PM
stephenw's Avatar
stephenw
You have to do some homework, but the www.kb-silvolite.com has a good calculator section. You can take a stab at it with data from the Christ' "Building Big Block Fords" book.
Old Jun 4, 2003 | 11:54 AM
chissler's Avatar
chissler
If I were to guess I'd say about 9.5:1
You'll need to know several factors to figure it out:
bore
stroke
compression height
deck clearance
head gasket thickness (smashed)
valve releif cc's
chamber volume
Old Jun 12, 2003 | 07:56 AM
redneck hillbilly's Avatar
redneck hillbilly
I have the same set up as you and have been trying to figure out the same thing. The stock motor would have 8.6:1 or 8.6:1. Like Chissler stated you need to know several factors. A book called High Performance Ford Engine Parts Interchange is good and can help. Like me you have probably realized that you need to cc your head and do several other measurements. It really is hard to know for sure. If this stuff was easy girls would be doing it.
Old Jun 12, 2003 | 08:24 PM
gktbay's Avatar
gktbay
thanks to all ... will soon be ordering the pistons and will get the machinist to calculate the answer.
Old Jun 13, 2003 | 12:22 AM
baddad457's Avatar
baddad457
If the casting #s on those 68 heads are C8AE-H then your comp ratio should be around 10.5 to 1 ( 67-69cc chambers) the bigger 71-73 chambered heads will lower it down a little to around 9.75 or there about.
Old Aug 19, 2003 | 05:30 AM
redneck hillbilly
I believe the compression ratio of a 2V is 9.5:1 and the 4V is 10.5:1. These ratios are for a stock engine.
Old Aug 19, 2003 | 06:00 AM
baddad457's Avatar
baddad457
The difference in the comp ratio, was due to the pistons. The 2 bbl could have either comp ratio in the cars , the 390 in my 68 Monterey had 10.5 to 1, while the motor I pulled from a 68 Galaxie was a 9.5 to 1 motor, both were 2 bbl. The difference was one had dished pistons and the other had flattops. Both had C8AE-H heads. If his replacement pistons have the same comp height as the factory flattops, then he'll get a 10.5 to 1 ratio
greentruck72
May 4, 2015 04:02 PM
Frankinstine
20
May 30, 2014 02:46 PM
jmcnair40
Nov 12, 2011 06:09 AM
adamraaron
Oct 20, 2007 12:46 PM
kenmt
Aug 2, 2001 01:38 PM
