Sponsored by: Real Truck
Oil pressure problem
Old Mar 26, 2013 | 08:01 PM
warcat's Avatar
warcat
Ok heres the problem me and my dad just rebuilt a 7.3 in a 2001 f 350 we got everything runnin the got about 200 miles on the rebuilt the one day the oil guage starts freaking out wehave replaced the sensor, pulledthe cooler to make sure the plug wasnt stuck. the guage sas the pressure is fine when the engine is revved up but when it idles it says it has no pressure. does anyone knowwhat else to look for. The engine is a rebuilt 7.3 turbo with oversized pistons everything else is stock.
Old Mar 27, 2013 | 12:22 AM
Yahiko's Avatar
Yahiko
When you did the rebuild did you clean the oil pressure regulator piston and bore?
If not that could be the problem. Get a pressure gauge on it and see what it is
really doing. If it is indeed dropping low at idle I would be thinking the reg.
Or a leaking gallery plug. Someone that knows more about the 7.3 is going to
have to chime in. You may want to post over in the 7.3 forum to get a better answer.
Please keep us informed on what you find.
Sean
Old Mar 27, 2013 | 07:29 AM
Snowseeker's Avatar
Snowseeker
Sounds like an oil pick up tube problem. Loose, cracked, or the like.
kenworth90
Apr 26, 2012 02:36 AM
bpdad
Jul 22, 2010 11:44 AM
lapwrstroke
Jun 18, 2010 09:28 PM
akdog1
Oil & Lubrication
Jul 12, 2003 11:27 PM
