Sponsored by: Real Truck
load resistor?
Old Mar 23, 2013 | 06:50 PM
montey2005's Avatar
montey2005
load resistor?
some time ago I started changing my lights to LED's and so far so good until I pulled the front blinkers and replaced them with these 2012 Ford F250 F450 Front Turn Signal LED Replacement Bulbs | LED Lights for Cars | 12v | Super Bright LEDs
I'm no engineer and wiring makes me crazy. I realize I need a resistor to slow down the flash rate so what is recommended and the easiest to do that I can find at an autozone and the like?
I'm all for changing out the entire headlamp assembly for projector beams too so throw those out if you have suggestions but don't make me miss a mortgage payment.
Old Mar 23, 2013 | 08:29 PM
meborder's Avatar
meborder
get them from the same place if you like:
Tail Light Load Resistor Kit | Car Bulb Installation Supplies | LED Car Bulbs | Super Bright LEDs
their price is pretty competitive most times.
good company to deal with, IMO
otherwise it looks like Radio Shack gets close:
NTE 50WF010 - 50W Vitreous Enamel Fixed Wirewound Resistor : Resistors | RadioShack.com
these are 10ohm vs 6ohm from Super Bright LED's. they would probably work, but for the sure thing, i'd order them.
Old Mar 23, 2013 | 08:51 PM
DanD2's Avatar
DanD2
Just get a digital flasher instead. That's what I did and it works fine.
Old Mar 24, 2013 | 01:10 AM
montey2005's Avatar
montey2005
what type of digital flasher and where can I get one?
Old Mar 24, 2013 | 06:28 AM
meborder's Avatar
meborder
i wasn't sure if the Super Duty's had conventional flasher relays still or not. if they do, that is by far the easiest route. most vehicles today do not have the flashing relay, so the load resistor will always work.
just go the parts store and have them look up a flashing relay and get the one marked "electronic" or "digital" and that will work. the last one i bought was about $25, but that was quite a few years ago.
super bright led sells them too.
2012 Ford F250 F450 Installation Accessories LED Replacement Bulbs | LED Lights for Cars | 12v | Super Bright LEDs
Old Mar 24, 2013 | 07:33 AM
DanD2's Avatar
DanD2
^^^^ Good point on the flasher. From what I can tell, the OP has a 2012 truck. Not sure if those have the flashers or not.
Montey,
You'll want to find that out first. If it does, definately the way to go. The next question you would probably ask is, where the hell is the flasher located???? At least on the 07's and earlier, it is located way up under the dash next to the radio. Best way to get it is to remove the dash. On my 06, removing the dash was very very easy. Less than a minute to take the dash off, took me about 10 minutes to disconnect the headlight plug. I was doing it in a low light situation and had a hard time seeing things (my old eyes didn't help either.)
Old Mar 24, 2013 | 09:56 AM
montey2005's Avatar
montey2005
thanks guys, I'll look into this and hopefully it's easy otherwise I'll find someone to add it.
Old Mar 24, 2013 | 05:02 PM
SteveC7010's Avatar
SteveC7010
What year is your truck? If it's an '11 or newer, don't buy resistors or replacement flashers. Take the truck down to your dealer and have them reprogram the BCM per SVE Q-158R3 to accommodate the LED's. The SVE can be found here: https://www.fleet.ford.com/truckbbas...ml/Q-158R3.pdf
Old Mar 24, 2013 | 05:04 PM
SteveC7010's Avatar
SteveC7010
Nope, no flashers in the 2011MY and up. It's all in the BCM now.
Old Mar 25, 2013 | 08:26 PM
montey2005's Avatar
montey2005
you wont believe this but the STEALER told me it's $125 to have the re-flash posted on the bulletin. What a crock of sh........t!!
Anyone know where I can find LED bulbs with built-in resistors?
Thanks.
Old Mar 25, 2013 | 08:57 PM
DanD2's Avatar
DanD2
Thanks.
WOW....what a rip off.
Go to superbrightledlights.com. They have some built-in resistor blinker (3157) led's for vehicles with a can bus system. I'm not 100% sure but I think they would work.
Old Mar 27, 2013 | 10:51 AM
montey2005's Avatar
montey2005
going crazy here, cannot find any lights with built-in load resistors. I did find this EP27L LED Bulb Electronic Flasher | Car Bulb Installation Supplies | LED Car Bulbs | Super Bright LEDs
question is how difficult is it to install?
Old Mar 27, 2013 | 10:59 AM
SteveC7010's Avatar
SteveC7010
Your truck is a 2012 so there is no flasher. It's all controlled by the BCM.
Here's some with the built in resistor:
Two Amber No Resistor Required 3157 3057 20 SMD LED Front Turn Signal Lights | eBay
Old Mar 27, 2013 | 11:32 AM
montey2005's Avatar
montey2005
will they work if I change the side marker lights as well?
Thanks
Old Mar 27, 2013 | 11:34 AM
DanD2's Avatar
DanD2
