4x2 oil pan replacement ?
Old Mar 25, 2013 | 03:23 PM
Twistedwrench's Avatar
Twistedwrench
I have a 2000 f350 4x2 7.3 stroke . Is it possible to remove the oil pan with the engine jacked up ; remove the CAC tubes and turbo charger for more room ?
Old Mar 25, 2013 | 03:37 PM
nlemerise's Avatar
nlemerise
I do not believe it is possible, though I might be wrong. People have cut the crossmember out & replaced the pan then replaced the crossmember, others have put a fiberglass shell around the pan, and others have pulled the engine. Of all of these, I think the pull and repair is the ticket...
EDIT: I just remembered this thread about a guy who thought about r&r'ing the pan with the engine in the truck.
Old Mar 25, 2013 | 09:49 PM
fordpride's Avatar
fordpride
You have to pull the engine. Don't cut the crossmember. You can pull the engine in the same amount of if not fast then cutting
Old Mar 25, 2013 | 10:44 PM
BadDogKuzz's Avatar
BadDogKuzz
You have to pull the engine and to do it correctly you need to flip the engine over so oil doesn't get on the gasket sealer.
Don't cut the crossmember. You'll ruin the frame doing that !
Old Mar 26, 2013 | 09:12 AM
Twistedwrench
That's the general consensus . I wanted to see if there are any quick tips . It's a 4x2 so pulling the motor is easy ...
jadockins
Apr 5, 2011 10:05 PM
99 F-250
Dec 5, 2009 06:30 PM
SMiddleton
19
Jan 5, 2007 04:14 PM
Quadrophenia_00
Jun 5, 2006 09:45 AM
skinny_ginny
Sep 26, 2004 11:22 AM
