IP Hotwire?
Old Mar 25, 2013 | 03:12 PM
REDNECKIT's Avatar
REDNECKIT
IP Hotwire?
Hey all. I recently took a 460 gas out of my 97 F350 and put in my 1992 7.3. The plug that comes out from the firewall on the passenger side is a different style than the one on my engine harness. I've been hot wiring it to the battery so she can run(Dont have to worry about the glow plugs cause i got a push button). Even if I just spliced these two wires together would it still work without hotwiring it to the battery?
Old Mar 25, 2013 | 03:48 PM
Chevy_Eater's Avatar
Chevy_Eater
What two wires?
All you should have to do is wire the IP FSS to a key on & key start hot.
Old Mar 25, 2013 | 03:53 PM
REDNECKIT's Avatar
REDNECKIT
Yea, Im asking if I could splice the wire from the firewall and the wire that goes to the fuel shutoff. Normally I wouldnt ask but going from a 1992 system to a 1997 is quite a ways
Old Mar 25, 2013 | 06:12 PM
Chevy_Eater
Well, since you're talking about a gasser truck it's not going to have a wire for the fuel shutoff. You are just going to have to find a wire that is hot with the key on and stays hot while cranking and tap into that.
Craig Terry
32
Mar 4, 2012 09:28 PM
dgrant09
Electrical Systems/Wiring
Mar 2, 2008 09:03 PM
pinaclan
Nov 26, 2006 01:00 PM
mydieselpower86
Jan 29, 2006 10:45 PM
