Hello Everyone. I have a 2000 Ford Excursion. My trailer hitch receiver rotted out. I called a salvage yard and asked for a hitch they sent me a hitch for a 2005 Excursion. Will it fit my 2000? I can visually tell that it is a different one.
This is the one on my truck now. It is also rotted even worse on the back.
Hitch from an 05 Excursion:
Im going to bring it to the shop next week. They said the only way they can tell if the bolt pattern is the same is to drop the fuel tank and see if there are extra holes in the frame. Thanks for your help!
Hmm your links seem to be Gmail linked and when I try it says Gmail unavailable.... I will try later....
To what I understand, excursion hitches r specific to excursions. No replacements r made. The only difference from I believe 00-01 to the 02-05 r the size of hardware used to bolt it to the frame. Not 100% on the year change in hardware but I know it happened and it also raises the tongue weight. I'm sure someone here will chime in the the exact years.
This is of course not recommended. What if you need to replace something underneath the truck and it's in the way? That's right just unbolt it an...... wait, it's permanent and you can't work on the truck now. Well damn. Do it right the first time
I know not what you do in "Merica" but mother Russia we make weld go buzz buzz! You no make how fix with out weld stick, da?
---------------seriously----------------------
I was totally joking about the welding part
Actually the entire part was kind of a funny post
