maintenance, modifications and add ons
Old Mar 26, 2013 | 09:24 AM
Pitcrw6's Avatar
Pitcrw6
Originally Posted by Diablo540
thanks for the info i saved all links in about 2 weeks ill start from front of truck and move back . just got new tires and rims today now its alot quieter but now i hear r/f hub starting to growl go figure i just replaced the vacume hoses to the front hub housing old stuff i pulled off had a bunch of crap fell out of it so either way i guess im pulling hubs to atleast clean out 1 and replace the other well here goes nothing lol hopefully this dont turn into a endless money pit . after hubs ill be moving to all filters and fluids then move on to extra oil filter mod coolant mod then fuel mod with extra filter all depends on costs money is a little tight since i had to buy tires and rims for this beast so i may hit up cheap/free mods inbetween theses. anyone have any of those abs sensor plugs to back grease the hubs? if so how much to get a set of them i really dont want to replace these hubs again i just looked them up and they are like 350$ each on rock auto but ill be shopping around to see if i can find cheaper
Send Andy (Snowseeker) a PM for the ABS grease fittings. He makes them up as people need them. Here is the link where he talks about it.
https://www.ford-trucks.com/forums/1...ub-zerk-9.html
Old Mar 26, 2013 | 10:11 AM
Diablo540's Avatar
Diablo540
Guess that hutch mod I should try , every once in awhile sitting at a light I get sort of a light miss fire . Sounds like the this could be the issue
Old Mar 26, 2013 | 10:46 AM
Pitcrw6's Avatar
Pitcrw6
To verify that is it you can disconnect the fuel line going into the pump and blow air back through the line into the tank to try and clear the screens. Make sure you remove your filler cap before blowing air back into the tank. Also are you above 1/4 tank? You might have a broken pickup foot also and if your below a 1/4 tank it can cause a slight missfire. To me doing the hutch/harpoon mod is the best anyway. I would put on a external filter from Strickly Diesel also.
Old Mar 26, 2013 | 01:10 PM
Diablo540's Avatar
Diablo540
I just got the truck only filled up 2 times I keep it slightly over 1/4 tank and just throw in $50 at a time so when weather breaks for a day I can do the mod but way weather has been it may be a few more weeks . Is the kit they sell worth it? Or should I piece it together and buy just the filter kit . It looks like its just a compression fitting and some steel brake/fuel line is all that's needed besides filter housing and nipples
Old Mar 26, 2013 | 01:13 PM
Diablo540's Avatar
Diablo540
Thanks for link I'll send him a message for sure
Old Mar 26, 2013 | 01:16 PM
Tugly's Avatar
Tugly
Originally Posted by stinson 108-1
Rich, thats the first time i've seen the pic of the 50 cent failure. How reasuring.
Yea... I've been slackin'. I took that picture during one of my multiple visits to the injectors under the VCs and I downloaded my camera recently. I uploaded that photo this morning.
Miss? Below 1/4-tank - maybe a Hutch mod issue. Possibly a UVCH issue if under 1/4, very likely if over 1/4.
Old Mar 26, 2013 | 01:42 PM
Diablo540's Avatar
Diablo540
Uvch? It only does it randomly and not very severe
Old Mar 26, 2013 | 04:10 PM
Pitcrw6's Avatar
Pitcrw6
You can piece the kit together or buy the kit. I went with simplicity and bought the kit.
Driven Diesel Fuel Tank / Pre-Pump Kit
Old Mar 26, 2013 | 04:49 PM
Diablo540's Avatar
Diablo540
Cool I'll prob go same route I don't think it will be much price diff if I piece it together anyways
knottyrope
Nov 21, 2016 10:51 PM
reluctantfiver
Aug 18, 2009 05:24 PM
riggz
Dec 20, 2007 06:20 PM
70T351W
Jan 22, 2007 06:35 AM
sneal
Oct 10, 2006 06:59 PM
