taillights acting up!!!!!! help
Old Mar 23, 2013 | 11:10 PM
puroford's Avatar
puroford
Hello,
I recently put the taillights back on the truck. I have a flareside so the taillights are the trailer lights. The problem is that they are acting up. I have not touched anything as far as wiring or switch, all I did was plug them into the harness. Here is what is going on. When I turn on the lights the left one lights up like normal and the right one is very dim. When I put the left turn signal, it blinks but very very slowly. When I put on the right signal, it doesnt blink and for some reason the left reverse light comes on. What can be wrong? Thank you in advance
Old Mar 23, 2013 | 11:26 PM
montana_highboy's Avatar
montana_highboy
Reverse the bulbs and see if the same issue is present, if so, reverse the flashers (under the dash) see if same issue is present...
Old Mar 24, 2013 | 06:17 AM
Canus's Avatar
Canus
Check your grounds.
Old Apr 1, 2013 | 04:00 PM
puroford's Avatar
puroford
Hello, thank you for the quick replies. I apologize for not following up sooner.
I checked grounds and they seemed fine, bulbs were good, so i replaced flasher.
Thats what it was, they are blinking like they should now. Thank y'all.
schmidtkenathan
Jun 14, 2019 11:53 AM
Iamopie2
Aug 26, 2017 04:06 PM
zdumpor
Mar 4, 2016 11:56 AM
johaner78
Jan 19, 2015 07:34 PM
4x2Fordman
Dec 18, 2004 09:07 PM
