Led rear lights issue
Old Aug 26, 2017 | 12:48 PM
Iamopie2's Avatar
Iamopie2
I swapped out the brake lights and reverse lights for leds and the instrument indicators flash really fast. The actual lights flash normally. I have load equalizers and put one in the reverse light and that didn't fix it. Any ideas? It's just annoying. Not an actual issue
Old Aug 26, 2017 | 02:02 PM
cficare's Avatar
cficare
You may need to swap out your turn signal flasher relay for an electronic version. The e-flashers don't rely on heat build-up to actuate the bulbs on/off. OTOH, an e-flasher will also not let you know when a signal bulb has burned out. DISCLAIMER - I do not know what type of flasher relay Ford uses nowadays, so I may be totally out in left field on this subject.
Old Aug 26, 2017 | 02:43 PM
user 474747383's Avatar
user 474747383
They don't use any flashers anymore, But the dealer can turn off the bulb out and your good to go no need for any equalizers. You can do the same with ForScan.
Old Aug 26, 2017 | 02:49 PM
Iamopie2's Avatar
Iamopie2
What does that mean to turn off the bulb out. I was going to try and put the equalizers on the tail lights and not the reverse light to see if that works
Old Aug 26, 2017 | 03:35 PM
user 474747383
You need to put the equalizers on anything that flashes 1 per bulb. So you need two for both sides. also for each front turn sig bulb. Easier to visit your dealer and have them turn off the bulb out in the settings. When you install led's it thinks there is a bulb out because led's draw less current so it fast flashes in the dash, like a bulbs out. Also you don't have to cut/crimp into your harness. You don't need any equalizers on single element bulbs reverse/tag/running.
Old Aug 26, 2017 | 03:36 PM
Blwnsmoke's Avatar
Blwnsmoke
Blinkers are controlled by the BCM... It is all computerized now. The dealer can use IDS and turn off the bulb out feature. Because LED uses a lot less power, the truck thinks it has a bulb burnt out due to little voltage being used. The BCM then commands a hyper flash (quick flash) to let you know it is out.
The dealer can turn this feature off so it will not think a bulb is burnt out and flash normal. Only downside is you will never know if a bulb is out.
This has been going on since the 2011MY.
Old Aug 26, 2017 | 03:42 PM
user 474747383
Wow almost a double post..LOL
Old Aug 26, 2017 | 03:48 PM
Iamopie2's Avatar
Iamopie2
Awesome thanks. I put load equalizers on both the lights on one side and same issue. So those didn't fix it. Sigh. So I'll call the dealer and hit them up. Thanks for the help
Old Aug 26, 2017 | 03:58 PM
user 474747383
Make sure you don't have any leds in any other light without equalizers. except you reverse lights you can leave those in.
Old Aug 26, 2017 | 04:00 PM
Blwnsmoke's Avatar
Blwnsmoke
You do not need equalizer or anything else. A simple setting change in the BCM fixes it.
Iamopie2's Avatar
Iamopie2
Dang. My local auto parts is now out of equalizers. I hurt have them on the right side (just did the rear). Should I look and spend the 15 bucks and install on the left or just go to dealer. I'm going to upgrade the front and headlights soon
Old Aug 26, 2017 | 04:02 PM
user 474747383
I don't like tapping into the Harness so if you can wait hit the dealer.
Old Aug 26, 2017 | 04:06 PM
Iamopie2's Avatar
Iamopie2
Thanks. Wilco
zdumpor
Mar 4, 2016 11:56 AM
KCFordFANatic
1997 - 2003 F150
Jul 18, 2015 05:13 PM
51PanelMan
26
Feb 16, 2013 10:14 PM
nateraz1
Dec 11, 2012 10:26 PM
Supercab
Electrical Systems/Wiring
Feb 20, 2009 07:04 AM
