Rusty lower doors :(
Old Mar 23, 2013 | 10:39 PM
fatherdano's Avatar
fatherdano
I can't imagine i'm the only one.
driver and passenger doors are starting to drip rust onto my running boards.
what is the best route to take?
I am not a body guy at all and i'd like to keep my ex for at least 10 more years.
Thanks
Old Mar 23, 2013 | 11:35 PM
VQT's Avatar
VQT
Search "snowseeker" thread he fix his doors I think
Old Mar 24, 2013 | 12:48 AM
1 Excursion camper's Avatar
1 Excursion camper
I fixed mine also. I cut off the inner lip of the door panel (the door skin that is folded over) this is where all my rust was. then I used some POR 15 on the inside of the door and on the removed rusty lip. I then used some 2 part epoxy/ filler to smooth out the removed rusty metal. I then used some high build (durable) stone/chip guard to paint the lower 2" of the doors. I have some pics and I will have to dig them out. It`s going on 2 years and they still look good with no signs of rust forming again!
BTW, it`s not just Ford. GM has the same problem also.
Old Mar 24, 2013 | 01:07 AM
garryk6's Avatar
garryk6
I have the same but worse problem on my 2000 XLT Ex. Someone already did a cheap repair.... Now my doors are gone at the bottom. I could replace the bottom inside and outside, but I am searching now for a pair do replacement front doors... I think that will be better and cheaper in the long run.
Good luck!
Garry in Kodiak, AK
Old Mar 25, 2013 | 12:16 AM
Sunline Fan's Avatar
Sunline Fan
Excursion Fleet Manager
I'm glad I've learned about this through FTE, because now wiping down the inside of the doors is standard procedure whenever I wash a car.
Old Mar 25, 2013 | 12:18 AM
abranz's Avatar
abranz
I fight this yearly with 6 months of salt on the roads. Once the repair is done coat the inside of the door with por 15 and then spray it with fluid film. You'll be impressed. Do the same with the rockers and the frame. It ends the problem, period.
1 Excursion camper
Mar 5, 2017 08:09 AM
psquare7575
13
Sep 1, 2008 05:28 PM
fiftysixfordf250
Mar 5, 2008 01:01 PM
JoeGodbee
Jan 9, 2005 10:11 PM
zakt
Jul 21, 2004 12:28 AM
