48-50 Door Woes
If the rust has eaten away the internal structure you may have to de-skin the door to make the repairs, and that can be a major project.
If there is just surface rust on the interior there are several ways to remove the rust, most use from mild to wild chemicals and can be a little intimadating at first glance.
A pickup bed lined with polythene makes a good dip tank
I replaced the bottom inner sections of both doors with repair panels from mid-fifty but they just seem to list parts from 53 - 56,
Some pic's in my gallery may give you a few ideas
No rust-through any where on the doors. Left door does have some minor surface rust (as seen in the photo) that can be repaired with little effort. Doors are straight.
I want to sell just the door shells, unless you need the guts of the door. You'd spend less time and money on these doors than repairing yours. There aren't any patch panels for the bottom edge. You'd have to fabricate it yourself. The doors are not being reproduced by anyone. You'd have to find an NOS door or a good used set, like mine.
I have the inner door panels available as well if you need them.
Let me know if the doors are of any interest to you. I am in San Jose, CA, and can figure out a way to ship them to you.
Ilya
I may be very interested. Can you send me more photos of the bad spots? Also, these are froma 51? Will they fit right up to my 49 cab? Also, I can see rust inside the door through the opening where the panel goes. Every set I see has this. How in the world do you get all that out?
The doors are from a '49 Panel truck. However, doors from 1948-1952 remained pretty much the same. There weren't any body changes in the inside and on the outside. Doors from any '48-'52 Bonus Built truck, except the COE's, will fit.
I will take more pictures as you requested and either send them to you or post them in this thread. I wouldn't worry too much about the inside surface rust unless it's really bad. If I were you, I'd try to sand as much of it as I can and then spray POR 15 inside on as much as I can. This is what I plan to do with my current doors on my '51 Panel.
You can also sound deaden the inside of the doors. Dynamat sells different adhesive sheets that will damper the sound and/or insulate the door. I am contemplating about doing this. I believe that there's also a spray-on sound dampering/insulating material.
Ilya
