P0221
Code P0221...Throttle Switch B Circuit Performance. Probable cause: Failed pedal assembly.
More info: Fault Detection/Management:
1. Any detected malfunction of the AP sensor will illuminate the Check Engine Light...Federal Calibration Only.
2. An AP signal that is detected out of range high or low by the PCM will cause the engine to ignore the AP signal and will only allow the engine to operate at low idle.
3. If a disagreement in the state of idle validation switch (IVS) and AP sensor is detected by the PCM, the engine will only be allowed to operate at low idle.
High Input:
Causes:
A: Damaged Accelerator Pedal
B: AP sensor may not be seated properly
C. Damaged AP sensor
D. Short to power in harness.
E. Damaged PCM
Low Input:
Causes:
A. AP sensor not seated properly.
B. Damaged AP sensor.
C. Open harness.
D. Grounded harness.
E. Damaged PCM.
Hope this points you in the right direction. PM me if you need the troubleshooting section. I'll copy, and send as attach pdf.
jeff
So i don't mean to be repetitive but just for others and now I'm on my pc i can go through and explain more in detail.
I have been using my truck only once a week since Jan 1, due to out of town work. Its been running great with no issues. Arrived home tues afternoon and have been using it everyday since. Yesterday it started raining and the wife and i went out shopping for some things. Drove ob 20 to 30 mi into town and back. Truck ran great. Came home for 3hrs truck sat, fired it up to go tot the wedding. Drove out the drive way and hit the main road into town running ob 50 to 55 mph on my 80e tune from DP. Got behind a slow car doing the ole 35 to 45, 35 to 45 deal. Not staying at a steady speed my truck would drop OD down to 3rd then T/C would lock then hit OD then Shift back to 3rd then T/C then OD. Thus only due to the slow car who can't hold a steady speed. So i turned the OD off to keep it from shifting so much.
The car slowed to a stop and turned, i turned the OD back on and took off regularly. When i flipped the OD back on i seen the SES light come on then turn right off. Right away i checked my DTC's using my dash mounted Edge Evolution " which is only for digital gauges and code reader " It read p0221 "Throttle Switch B Circuit Performance." I cleared the code. Upon take off it shifted from 1st to 2nd then to 3rd for a split second then the T/C locked up almost the same time it shifted to 3rd. It did this all the way to the wedding. Even with the OD off or on and in Stk tune and 80e. After 4hrs of off time while at the wedding i fired it up and was ready for a long ride home. HAHA nope she ran perfectly normal the entire way back home..... roughly 20mi. WEIRD !
I noticed what felt like a bit of a delay upon acceleration in the pedal. Immediately i thought TPS. But if it is WHY would it still go accelerate fine but shift like that........
So back in 2010 i had what felt like a dead spot in my pedal. It would shutter or cut out when held at a certain spot. So i ordered a new one from ED. Installed it and had no issue till last summer. The dead spot came back so i put the old " original one " back in and it was fixed.
So Al and Jeff.... Thanks i am planning on cleaning the pedal assay but need a food write up on it if y'all can send me a link.
Jeff excuse my dumbness but "AP" whats the AP sensor where is it located and whats its purpose ? and why would this cause it to shift like i stated ? It idles fine and revs fine it just threw the code and started shifting all funky like i explained earlier above.
Im about to run to the shop about a 5mi drive down the road. Id like to clean the tps sensor but can't find a write up on it.
Here are some pics for reference though in this thread.
https://www.ford-trucks.com/forums/9...ensor-fyi.html
I would follow what others have stated and clean the sensor first before replacing.
Jeff
Jeff
Took it out and used a light amount of contact cleaner and compressed air to clean the tab and button on the IVS and all the pivot points on the pedal assy its self, after removing the TPS. After cleaning i applied a decent amount of silicon spray to all the pivot points and to the tab and button on the IVS.
As for the TPS its self i couldn't find any way to really clean it...... the back of it where the pedal inserts in to it looked very clean and still had the factory white lube on it which was debris free and looked brand new. Its sealed very tight and couldn't even see how you could clean that part to be honest other than the connectors which looked awesome !
Re-installed and all is working fine. Like i mentioned after its episode on the way to the wedding all has been good. The drive home last night and to the shop this morning " Pre Pedal Assy Cleaning " was great and then back home from the shop " Post Cleaning " was great and the pedal felt greatly smoother.
My concern is most that i have read up on this issue with others if they get Code p0221 or dead pedal, it works or it doesn't . I haven't read anything describing a truck shifting the way mine did anywhere involving the p0221 code.
Im wondering also if chaffed od wires in the column could cause this ? idk haven't checked them but am planning on it as primitive maintenance.
As long as the P0221 code doesn't come back your back in business.
jeff
How many miles on the transmission? Have you ever done the trans flush or replaced the filter? If not, I'd complete a trans flush with new filter. Put a 3/8" in line Magna-Fine filter on the return line out of the cooler. Here's a link: https://www.ford-trucks.com/forums/1...and-video.html
I would also take a fluid sample and send it to Blackstone for analysis.
My E99 has 268,000 miles on the original trans works great. Never had a problem shifting and I tow a gooseneck horse trailer and haul around a 9.5' cabover camper. No repairs to the transmissions. I service the trans on a regular basis with oil analysis. Wear metals are constantly low and there is no trace of in-solubles.
