Missouri Chapter Join Chapter , Leader:77&79F250
HELP!
Old Mar 22, 2013 | 11:05 AM
garrett_8's Avatar
garrett_8
HELP!
ABS and parking brake light come on after about 30 min of driving any ideas?
Truck is a 93 F150 5.0 Auto 4x4 4wd, and i have checked fluid is full
manual hubs if that matters push button 4wd 185k on it
Old Mar 22, 2013 | 11:16 AM
earthquake68's Avatar
earthquake68
A '93 has rear ABS only. If the pedal feels ok, it's probably the wheel speed sensor on the differential. I'd check for broken wires. The parking brake light will light with a faulty ABS sensor too. I'd check that out first. It could be a bad sensor, too. Know anybody that can run the ABS computer codes? (a standard code reader only reads engine codes, you need a different computer to talk to the ABS computer)
Old Mar 22, 2013 | 12:31 PM
garrett_8's Avatar
garrett_8
im an equipment sales coordinator for oreillys ill take a genysis home this weekend
Old Mar 22, 2013 | 01:52 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Take it to almost any auto parts store Auto Zone ect.... and have them plug a code reader (for free) into the OBS and see what code it throws.
Sounds like a sensor is bad if the brakes are still good.
Old Mar 22, 2013 | 02:52 PM
garrett_8's Avatar
garrett_8
cant pull an ABS code with a reader hooked a genisys to it said i have to unplug some wires and watch the light blink to pull an ABS code, went ahead and ran the codes and pulled a 63 which seems to be a TPS issue, which would make sense since sometimes when i start the truck the idle will bounce back and forth
just another project gotta finish the exhaust and do the ball joints too ugh
Old Mar 22, 2013 | 02:53 PM
garrett_8's Avatar
garrett_8
autozone is the devil lol
Old Mar 22, 2013 | 06:50 PM
earthquake68
At least you found it. (and it's a cheap fix)
Rich, geez, didn't ya' read where I said a code reader wouldn't do it??
Old Mar 22, 2013 | 07:55 PM
77&79F250's Avatar
77&79F250
No I did not, oops.
Old Mar 26, 2013 | 08:40 AM
garrett_8's Avatar
garrett_8
and he recommended autozone after i already said i work for oreillys
Old Mar 26, 2013 | 08:47 AM
cyclopsblown34's Avatar
cyclopsblown34
Autoshack er I mean Autozone is the worst around, even worse that Rot Auto in my opinion. I like my local independent parts store, their new guy has been there since 1981 and they know their way around a vehicle. Slo Reilly here in town is pretty good too.
Old Mar 26, 2013 | 02:26 PM
77&79F250's Avatar
77&79F250
I read that you are equipment sales coordinator for O'reilly's, I figured a suggestion that might help would be better than none at all.......
Even though my suggestion didn't help at all, at least it was a attempt to help.
Though that maybe Autozone might have the test equipment that would help......
Old Mar 26, 2013 | 04:33 PM
garrett_8's Avatar
garrett_8
just giving you crap, nice thing about working up here is we have "used equipment" allot of it is shop equipment that got repo'd or what not, i can take it home to use it on the weekend should help when i do my ball joints
Old Mar 26, 2013 | 04:37 PM
77&79F250's Avatar
77&79F250
Wow I quilted you into a quick reply....got ya. Jk its all good.
You going to the Fair Grove swap meet on the 6th of April?
Old Mar 26, 2013 | 05:23 PM
cyclopsblown34
Autozone's gimmick is you buy the parts there. Slow Reilly you pay the price of the tool and then get a full refund when you return it in good condition.
bubba_3711
Apr 22, 2017 10:38 PM
spinella
Jun 22, 2011 01:24 PM
hammerhead90
Dec 27, 2010 08:10 AM
Thudpucker
1997 - 2003 F150
13
Nov 10, 2009 12:33 AM
GREATWHITEHUNTER
Sep 16, 2009 10:09 PM
