will this engine work
Old Mar 22, 2013 | 04:28 PM
jowilker's Avatar
jowilker
Sgt. Sometimes we have to ask the poster hard questions because folk come here and we can't see what you have, no idea if you can fund a project, have a place to work or anything else. I am gonna suggest you are looking to spend $6-10,000.00 to get the project complete. I have been at this long enough to try to offer suggestions that will get you into a project that may give you a better end and not have you beating your head against a brick wall.
John
Old Mar 22, 2013 | 04:53 PM
sgthopkins's Avatar
sgthopkins
Jowilker, I do understand your outlook. I have pics posted in an album on here if you want to search, I just gotta fig out how to post em. Yeah I will prob have around 4000 ish In the truck but I have forever to do it. I'm just 34. I will look forward to learning from you and others on here.
Old Mar 22, 2013 | 07:22 PM
jowilker's Avatar
jowilker
I hear you, I have two sons older, I have about $9,000.00 in my truck and it is yet to be painted. Your $4,000.00 is too low.
John
Old Mar 23, 2013 | 09:09 AM
37 Ford guy's Avatar
37 Ford guy
Originally Posted by sgthopkins
Cropdusterman, thanks for the info. I plan on building this truck, the interior has had some work done already that I gotta finish but that is all. The shifter is already in the floor also, it has a new gas tank so an inline pump I assume will be needed for the 5.0.
Hey Sgt, is your new tank in the cab or under the bed?
I'm still in the process of plotting & planning the 5.0/AOD EFI swap into my '66 F100 while continuing to use it as my daily driver. I got the engine, trans, harness, computer, etc all from the same donor, a '92 Mustang GT and I'm basically adapting that whole setup into my truck. There's a lot of info online and I've posted some of it in my thread on FTE. Will post more as progress continues.
Initially, I was going to use the in-cab tank so I got all the hi-pressure fuel delivery setup from a late 80's-early 90's F150 which mounts on the frame rail below the cab. Then I changed my mind and went with the 66 Mustang style tank setup for EFI with in-tank pump mounted under rear of the truck.
All that to say, you have a lot of options and there's a lot of info to help you with your process. Keep us posted and figure out that pic thing! We like pics!!
Old Mar 23, 2013 | 03:01 PM
charliemccraney's Avatar
charliemccraney
For the topic, I think a 351 will work great. Even a roller cam 302 would be a good choice.
Off topic,
I agree with John. You need to re-evaluate the situation, particularly since you want a "clean, but nasty mean truck." To me, "clean" means nice looking paint, some custom touches, a nice interior, etc. You can easily exceed $4000 with that alone. To me, "nasty mean" means that it has some power which calls for engine and drive train modifications. Again, that alone can eat up $4000 quickly.
I didn't see the bed in your pictures. Do you have it?
If you can do body, paint, interior, engine, and drivetrain work yourself, then maybe you can do it within your budget but if not, you're going to need more money.
I've never done a complete restoration. I'm sure my truck will never be "finished." What I have learned from the small projects is that you need to expect to pay 1.25 to 1.5 times your best guess of the cost. Even with small projects there are things you will forget about at the beginning. There are things that you just won't know about until you've started and are taking things apart. There will be 50 years of previous owners' best ideas to correct. There are thing that just can't be accounted for completely at the start.
My suggestion is to sit down and write down everything you want to do and make your best effort to determine the cost. When that is done, add 50%. If you can't afford that, trim things that are not absolutely necessary from the list and see if you can get it close to an acceptable cost. And hey, if you're getting close to the end, you can see the light at the end of the tunnel and you're under budget, by all means spring for something you knocked off the list. But the point is you'd rather come in under budget than to go over and not have enough money to finish the project.
Old Mar 23, 2013 | 04:01 PM
sgthopkins's Avatar
sgthopkins
37 FordGuy, my tank is in the cab. I would like to put it under the bed, and have the filler be behind the brake light, but since it is a brand new tank then I will prob just leave in where it is unless I cannot get the fuel pressur I need. I will also check out your build from you 92 Pony, I don't know if I have enough skill to pull of a swap like that, but I plan on trying.
charliemccraney, I have no time limit so I am not going to be trying to rush this at all. When I say clean, I mean good paint, good interior, I would like to put the master cylinder under the cab and maybe put the battery somewhere hidden. I want the enginge comp to be free of anything I can hide. I like rat rods, but I want comfort so I will to rat it out per se buy I will keep it clean. Nasty means power, I want power. Fuel milage doesn't mean much to me since it will not be a daily driver.
I do have the bed, the guy I bought it from is doing the body work on it for free, he is a friend, I will do the rest of the work in the engine, the cab, and body prep myself so that is where I plan to save my money. I will pay to paint it but plan to do everything else myself. I know that I will have hidden things that will eat up money but I don not know what they are yet. I have had the truck for bout a week and it has rained every day so I don't get to spend time with her yet. I do know that the owner put down carpet without fixing the holes in the floor so i will have to redo his work on that. The rest of the cab looks pretty good, the dash and instraments and such. Like I said, I have no time limit, I plan on take all the time I can on this. I built a 73 charger once and I rushed it then sold it. I want to go slow and keep this truck forever. I have four kids to pass it down to.
Old Mar 23, 2013 | 04:36 PM
arctic y block's Avatar
arctic y block
Could we see some pictures? Here is how.
Quote:
Originally Posted by 76f350spercamprspeal
Welcome to FTE, Best Damn Forum EVER!
Here's How to Post Pictures:
1. Login to FTE.
2.Click User CP (In the Top Left Hand Corner)
3.(On the Left, There will be a list, The 5th Option Down, will say "Pictures & Albums) Click That.
4.Then, Click Add Album, Enter a title, and description, if ya want to.
5. Click Upload Pictures, Then click Browse, Locate the Files of your truck. (You can add 3 files at a time)
5. Click Upload.
6. Add a description to the individual pictures, then click save.
7. Add more files if ya want.
8. Click The Picture you want to post, it will give you two codes at the bottom, Right Click The Second one (It say's BB Code, Then Say's [IMG]http:blahblahblah...[/IMG])
Then, Once that is highlighted, Right Click, Then Copy, Then Paste it into your post.
You can add up to 30 Images in one FTE Post.
If, Ya need any help, Don't hesitate to ask.
Quote:
Originally Posted by old_dan
You can also go to the "Garage" tab and start an album right here on FTE. After you post pictures to an album, we can look in your album, but you'll also be able to "insert a picture" by pasting in a link to the picture in your album.
It seems awkward, but whenever you "insert a picture" to one of these threads, the forum is looking for the picture somewhere on the web (which is always available) rather than from somewhere on your hard drive (which isn't always available).
Quote:
Originally Posted By Jolly Roger Joe
Welcome to FTE!
Go to Image hosting, free photo sharing & video sharing at Photobucket and sign up for a free account. Then create an album for your truck. Upload any pics you want to post on FTE to that album. Have this album open on your computer when you want to post pics on FTE.
While you're making a post on FTE, select the pic you want to post from your Photobucket album. When the large version of the pic is open, right mouse click on it and select "View Image Info". The image info will be highlighted and will look something like this:
The best photos and videos | Photobucket
Copy that highlighted info (right click / copy).
When you have the spot in your post where you want the pic to be placed, select the "Insert Image" icon at the top of the post (looks like a mountain) and paste (right click / paste) the image info you copied in the highlighted box (just shows "http://" when it opens).
Your pic will be placed in the post.
Hope that helps.
Here's a tutorial Bob put together: https://www.ford-trucks.com/forums/67...-pictures.html
Old Mar 23, 2013 | 05:18 PM
sgthopkins's Avatar
sgthopkins
Ok, I am sorry these are sideways, I took them with my Iphone and used it like a camera instead of a phone, which turned the pics. I will try to get more later and hope to have them the right way....
Old Mar 23, 2013 | 05:20 PM
sgthopkins's Avatar
sgthopkins
Thanks for the help AYB...
Old Mar 23, 2013 | 07:02 PM
sgthopkins's Avatar
sgthopkins
More sideways pics . As you can see, the inner fender wells are not rusted, the drip guards are not rusted, the floor which is not pictured is not rusted either. The corners of the cab are not bad either, there are some small holes about the size of a dime that I will cut out and patch. I don't think I will need to replace the whole body mount or door jabs. They look pretty good. The truck has new shocks, new break lines, new break pads, and new seats which are not pictured. I will work on the sideways pics too.
I don't know when it was last driven but the last inspection sticker was 1996, who knows after that because inspections are no longer needed in AR.
Old Mar 23, 2013 | 08:18 PM
arctic y block
Y
o
u
b
e
t
B
u
d
NewClimber
Sep 2, 2017 04:04 PM
customtronic
Mar 21, 2016 11:28 AM
Clayton Bennett
19
Apr 8, 2014 02:13 PM
wolfrages
Aug 20, 2012 09:36 PM
dla4634
Mar 3, 2003 07:26 AM
