1978 - 1996 Big Bronco
problem engaging the starter
Old Jun 3, 2003 | 12:08 AM
ya sure's Avatar
ya sure
I have a problem getting my starter to engage. If I play with the shifter on the columm it will engage the starter and the engine will run. I thought it was the nuetral safety switch (which is in the auto trans) So I disconnected the shift linkage at the transmission and left it hanging, with the trans is park and the shifter in park, I then tried to start the truck. I still had to play with the shifter on the column to get it to start. I don't get this. The linkage was disconneted from trans and I still had to play with the shifter. Could there be a problem with the igntion switch that is at the base of the column? And all I'm really doing is just amusing myself thinking it is the nuetral safety switch?
Thanks
Old Jun 3, 2003 | 09:10 AM
fcarruth's Avatar
fcarruth
I had a similiar problem a few years ago and my shift tube had to be replaced since it was allowing too much movement within the column. I didn't do the work myself because I hate to deal with steering wheels etc...
Old Jun 3, 2003 | 09:42 AM
Bodyman Chuck's Avatar
Bodyman Chuck
don't know what year you have , but pull the panel under the column on the top of the column is the switch try turning the key and moving the switch or just see if the switch is loose. do you have tilt wheel.the shift tubes do break if you use the wheel as a handle to get in with,but not a real common problem.i'd guess the switch is loose
Old Jun 3, 2003 | 10:59 PM
Trucky18's Avatar
Trucky18
i had a similar problem, the fuse in the fuse panel was loose, and when i jiggled the shifter or hit the colum it would work
Old Jun 10, 2003 | 07:19 PM
ya sure's Avatar
ya sure
I replaced the ignition switch on the column today. It works great now. By moving the shift lever I was also moving the rod a little bit and this was enough to get the truck started. It was easy to do. I didn't have to lower the column as the book says, just remove the aluminium mount for the column and remove the switch. It took about 15 minutes. Best 15 minutes of work on that truck yet. Thanks for the suggestions
Old Jun 23, 2003 | 01:01 PM
fuelieF100's Avatar
fuelieF100
how do you get to that switch to replace it? pictures, directions, anything would help.......
Old Jun 23, 2003 | 03:48 PM
fuelieF100's Avatar
fuelieF100
nevermind, just did it. piece of cake. Didn't solve my problem though. The actuator and rod seem to be ok, but the shifter is locked, what now?
Ronnief150man
Dec 8, 2016 10:19 PM
SwampFox112
16
Sep 14, 2016 11:12 PM
kdaug5
Nov 30, 2015 10:49 AM
esmarkey
May 30, 2013 07:33 PM
exploranger
1983 - 2012 Ranger & B-Series
Jul 16, 2006 04:05 AM
