No Start w/codes and AE....HELP!!
Old Mar 22, 2013 | 02:46 PM
  #46
tdpower's Avatar
tdpower
Originally Posted by KH85
Ill make sure to clear the codes. Is it ok to start it with the intercooler tubes and intake off as well??
On the bolt I cant get a long 13 in there with any kind of an extension on it. Do you cut away that sound deadener/heat shield stuff??
You might try a 1/4 socket wrench if you have one.
  #47
Shake-N-Bake's Avatar
Shake-N-Bake
Yes, just make sure nothing gets sucked into the openings.
I don't think an extension will fit. I didn't have to cut away any of the sound proofing though.
Old Mar 22, 2013 | 02:56 PM
  #48
Tugly's Avatar
Tugly
My "kit" has a 13mm deep socket and a universal joint. This gets the drive just clear
of the VC. When you go to put the VC back on, always start with the firewall bolt and use the hand that matches the side you're on: Left side, left hand to start the bolt.
Passenger side is the killer, particularly on the Ex. Go to Sears and get yourself a 13mm flex socket, or go to Walgreens and get yourself some asperin
[LINK]
Old Mar 22, 2013 | 02:59 PM
  #49
tdpower's Avatar
tdpower
TEST RESULTS GOOD!!
Injectors:
#2-2.7ohms
#4-2.3ohms
#6-2.8ohms
#8-2.7ohms
Number 4 injector solenoid might cause a problem. I would clean the 42 pin connection for it and retest also test at the 9 pin. A borderline injector solenoid can cause the whole bank to shut down. Something to keep in mind if you have problems with that side.
Old Mar 22, 2013 | 03:15 PM
  #50
KH85's Avatar
KH85
Well fingers crossed everything is looking good now! .25cents down .25 to go.
Still wondering about running the truck without the IC boots and intake though? Should I put those back on before test fire??
EDIT: Apparently my lap top is slow as hell out here in the shop!! I was able to get the last bolt with a deep 13 and a swivel adapter in 3/8. I did have to cut a little of the heat shield stuff away though but not much. Once I get the other side done I will hook everything up and test fire.
What do you use to clean the 42 pin connector with?? Which is pin 9?? Are you referring to the IDM or 42??
Old Mar 22, 2013 | 03:37 PM
  #51
Pitcrw6's Avatar
Pitcrw6
I use contact cleaner that you can get at any parts store. The 9 pin tdpower is talking about is the 9 pin connector that connects to the outside of the valve cover gasket.
Old Mar 22, 2013 | 03:57 PM
  #52
tdpower's Avatar
tdpower
Like Rob said the 9 pin on the outside of the valve cover. Test I to c and glow plug to ground . The pins will be arranged like this:
G - G - I - I - C - I - I - G - G
G = glow plug
I = Injector return
C = Injector common feed
You should read about .4-2 ohms for glow plugs and want to see consistent reading for I to C
Old Mar 22, 2013 | 04:31 PM
  #53
Tugly's Avatar
Tugly
Contact cleaner spray, compressed air, and a dab of dielectric grease on the face of the part without the pins. Do this on all connectors and you'll be restoring them to factory fresh.
I've run Stinky many times with no VCs on and turbo completely open (idle only). Just make absolutely certain no shop towels, rags, kleenex, or cobwebs are nearby. If the dog is shedding, keep that away too. There is a tiny black hole in the turbo that sucks all matter/energy (including sunlight) within 3 feet of it. If you drop a plastic bag in the bed of the truck, I swear it will find its way into the turbo. Don't even look at the damn thing... it may tempt you to point at it and you'll lose a fingernail.
Old Mar 22, 2013 | 04:40 PM
  #54
KH85's Avatar
KH85
Ok so I checked the 9 pins and both ohm out perfect. Problem is now that I have the 50 cent mod done and ready to try to fire im not getting any readings from the 42 pin to the 1,3,5,7 (pass side) injectors but 2,4,6,8 test just fine. Am I missing something??
EDIT: Um duh, I tested them using the D+....they tested out just fine!!
Old Mar 22, 2013 | 05:35 PM
  #55
KH85's Avatar
KH85
So I still have nothing!!.....put all the connectors back together double and triple checked everything 9pin ohms good, 42 pin ohms good, IDM harness ohms good, and still nothing.
When I put it back on AE I cleared all the codes and did a KOEO and got nothing. Then did a buzz test again and still no "buzz" and codes for open right bank and open left bank!!
What's going on now?? Is it the IDM itself or a relay for the IDM?? I checked all the fuses under the dash and still none are blown.
Old Mar 22, 2013 | 05:43 PM
  #56
Pitcrw6's Avatar
Pitcrw6
Are you getting a wait to start light?
Old Mar 22, 2013 | 05:48 PM
  #57
KH85's Avatar
KH85
Yes I am, I have a GP LED as well to if that matters. It appears everything is working fine as far as in cab pre-start stuff.
Old Mar 22, 2013 | 05:52 PM
  #58
Pitcrw6's Avatar
Pitcrw6
Have you checked the tin nut on the IPR to make sure its tight? Did you pull the ICP connector and try and start it?
Old Mar 22, 2013 | 05:56 PM
  #59
tdpower's Avatar
tdpower
Sounds like the idm to me. If you take off the cover of the idm you will probably find some fried resistors. You have to remove the bolts on the cover and then cut around the seal. Here are a couple of threads you can check out: Google
Old Mar 22, 2013 | 05:59 PM
  #60
KH85's Avatar
KH85
Tin nut is tight on the IPR and I pulled the ICP connector before I tore into and it didn't start, but I haven't tried that since tear down.
I will pull the IDM and see what it looks like.
