What engine to build 352,360,390 ???
so this question has been asked sooooo many times .
I decided to run a Desktop Dyno 5 sim for each
each with the same set up otherwise .
here's the specs i used for all three engines
STOCK BORE
STOCK HEADS with 2.02/1.56 valves
Compression Ratio 8.5:1
STOCK INTAKE 2bl
carburetor 2BL 350CFM
STOCK EXHAUST
LUNATI 62000 CAM basically an RV cam
Advertised Duration (Int/Exh): 250/256 Duration @ .050 (Int/Exh): 207/213 Gross Valve Lift (Int/Exh): .503/.524 LSA/ICL: 112/108 Valve Lash (Int/Exh): Hyd/Hyd RPM Range: 800-5000
STOCK BORE
STOCK INTAKE 2bl
STOCK EXHAUST
fiftyfordfloored
15
03-23-2015 08:43 AM
GaRedneck91
17
09-09-2014 04:53 PM
fordeverpower
06-16-2004 03:25 AM
Charles-65F350
07-17-2001 12:57 PM
