will someone run dd for me!
Old May 6, 2004 | 10:42 PM
fordeverpower's Avatar
fordeverpower
390
.030 over
d2 heads Milled .010
stock 4bbl intake
dual exaust (2 inch) Stock manifolds
mogual replacement pistons (4 valve reliefs)
670 holley
1 inch carb spacer
rv cam specs @ .050 204 intake, 214 exhaust
282 adv duration, 292 adv duration exhaust
valve lift .484, .510 (based on 1.73 ratio)
lobe seperation 112
lobe centerline Int 107, Ext 117
Old May 6, 2004 | 11:17 PM
Ratsmoker's Avatar
Ratsmoker
Here it is. Find out is those advertised specs are at .004, .006 or if they are the gross measurement.
Old May 6, 2004 | 11:35 PM
fordeverpower
Thanks Sean!
I can't get anymore specs at the moment. I have the MTF-4 melling cam. Its pretty close to what i figured which was 250hp and 350tq net.
Old May 7, 2004 | 05:10 PM
Ratsmoker's Avatar
Ratsmoker
That cam is going to sound a little less lopey than the Edel RPM cam. Those are serious advertised durations there. The .050 is pretty small but .050 doesn't matter when it comes to idle. Overlap is overlap no matter how fast the valves get thrown off the seat.
Old Jun 16, 2004 | 02:17 AM
fordeverpower
hey Sean, I am thinking about some rpm heads and intake and wonder if you could run it again with rpm heads and rpm intake. Thanks.
Old Jun 16, 2004 | 03:25 AM
fordeverpower
add throw in some 1.75 inch longtube headers! and compression is currently 9.2 to 1.
