Won't start/roll over
Old Mar 20, 2013 | 09:12 AM
Fordboy350's Avatar
Fordboy350
Hi guys, got a 96 F350 4x4 here with a e4od that won't roll over. Batteries are up and good, when I turn key ahead to start, I don't even get a click or anything. Its acting like its not in Park or Neutral? It has a brand new starter,and good cables and battery connections. Options? Ideas?
Old Mar 20, 2013 | 09:54 AM
Talyn's Avatar
Talyn
if your not getting a click, then the solenoid is probably bad.
passenger side fender well. Trace the wires from the battery.
Old Mar 20, 2013 | 10:02 AM
madpogue's Avatar
madpogue
Try it in Neutral. Then try moving the shifter around while holding the key.
If you have an assistant, pull the small wire off the relay and check for voltage there while your assistant turns the key. If there's voltage, then it's probably the relay. If no voltage, then it's upstream - ignition switch, neutral safety, wiring, etc.
Old Mar 21, 2013 | 11:11 AM
Fordboy350's Avatar
Fordboy350
So here is update. Haven't had time (due to work) to trace wiring. Truck starts if u jump the soleinoid, but the speedo and odometer don't work. The rest of dash works fine. Any idea how these problems are related?
Old Mar 21, 2013 | 12:21 PM
madpogue's Avatar
madpogue
Does the odometer show the number, just not counting up? Or is it blank? Does it shift normally or is it banging?
Have you checked ALL fuses in BOTH fuse boxes? Speedo/odo and starting problem may not be related.
Did you jump the _relay_ on the fender, or the _solenoid_ on the starter?
Old Mar 21, 2013 | 02:48 PM
Fordboy350's Avatar
Fordboy350
Relay on the fender, odo is blank, speedo is sittn on bottom, and shifting seemingly is fine. Haven't checked fuses yet.
RangerBee
1983 - 2012 Ranger & B-Series
19
Aug 30, 2014 10:17 AM
2000f1505.4
1997 - 2003 F150
May 16, 2012 11:26 PM
ptt
Jan 31, 2006 07:35 PM
JasonD
Electrical Systems/Wiring
Jul 17, 2003 06:23 PM
bowez
Apr 18, 2003 01:32 PM
