Transmission problem
Old Mar 19, 2013 | 05:34 PM
rooster159's Avatar
rooster159
New to this site, hoping someone can help us. Just bought a 2005 F150 supercrew 5.4 3v. It drove fine during the test drive, the motor was just a little rough. My husband put a little fuel treatment in, and it smoothed out. We put about 100 miles on it and it started acting up. When you take off from a stop, it gets to about 35 mph and suddenly upshifts, then downshifts back and forth rapidly. Then if you let off the gas, it quits. It drives normal after that. This has happened several times. Anybody else have this problem? Any ideas what is wrong? Or did we buy a lemon? My husband loves this truck, he's hoping it is something simple.
Thanks,
James & Sue
Old Mar 20, 2013 | 11:27 AM
70f100longbed's Avatar
70f100longbed
Are you sure it is shifting rapidly? The Rpms will jump up and down if it was. It almost sounds like you have a misfire. Cancel overdrive and see if it still does it.
Old Mar 21, 2013 | 09:01 AM
tooldad's Avatar
tooldad
Does sound similar to some misfire symptoms.
Old Mar 21, 2013 | 11:34 AM
1979 Ford's Avatar
1979 Ford
I am guessing a misfire. Which I'd venture to guess it is a coil pack. If so the fix is easy and lot cheaper then a transmission.
Old Mar 22, 2013 | 03:39 AM
rooster159's Avatar
rooster159
misfire I would of never gess that.no the rpms not jumping. i'll get plugs and coil pack
put on it thank you.
Old Mar 22, 2013 | 09:15 AM
1979 Ford's Avatar
1979 Ford
Check the codes first so you're not hanging parts. The codes should be pretty specific.
Old Mar 22, 2013 | 01:32 PM
rooster159's Avatar
rooster159
Any suggestions as to where to take the truck to get the codes, other than dealer which will prob. charge an arm & a leg?
thks,
Sue
Old Mar 22, 2013 | 05:45 PM
1979 Ford's Avatar
1979 Ford
I'd suggest an independent mechanic. Autozone and other parts stores will offer to read the codes with hopes that you buy parts from them.
ASE certified mechanic is a good piece or criteria to look for.
Old Mar 22, 2013 | 10:30 PM
70f100longbed
Don't write off the dealer so quick, Many are competitive with a lot of ind shops. It pays off to call around
Old Mar 22, 2013 | 10:40 PM
countryboy8085's Avatar
countryboy8085
I'm not sure where you are, but Midas has surprised me quite a few times lately. Have been in a few times and no problems. Even had the one in Omaha, Nebraska install my exhaust and stack kit. Tell you the truth only reason I went in there is because my wife had to pee and that was the closest place. Ended up with really good service.
aquaholic
2004 - 2008 F150
18
Sep 12, 2023 11:30 AM
85MD
Oct 21, 2014 08:39 AM
broncobilly66
2004 - 2008 F150
13
May 27, 2011 04:50 PM
madda
2004 - 2008 F150
Aug 13, 2010 12:03 PM
