Sponsored by: Auxito
performance
Old Mar 19, 2013 | 08:15 AM
corruptedgunz's Avatar
corruptedgunz
performance
I have a 2002 f150 5.4L 4x4 how can I increase my horsepower and foot pounds of torque with what performance parts or easy upgrades
Old Mar 19, 2013 | 08:43 AM
TrdLtly's Avatar
TrdLtly
TreadLightly
Try searching.... it has only been discussed a couple hundred times. (not trying to sound sarcastic). It really has been discussed A LOT.
Ford Truck Enthusiasts Forums - Search Forums
You may also want to scan through over here also: https://www.ford-trucks.com/forums/forum48/
Old Mar 19, 2013 | 01:18 PM
Bluegrass 7's Avatar
Bluegrass 7
Torque at low rpm is hard to improve upon from outside the system as designed.
Reason is you can't get very much more air through the motor than what can be drawn in and exhausted with the stock equipment.
It was not designed with very much built in restriction that would strangle the motor at higher rpm but was designed for truck applcations..
Such items as short headers provide little to no gains for gasflow tuning reasons.
Cat changes don't improve much.
The three best ways would be to lower the gear ratio as far as torque mutiplication goes, improved torque converter that allows the motor to stall it higher in rpm and torque range, and forced inducton using positive displacment super charging.
All of these are of substantial expense.
Bottom line is you won't get very much improvement with commom exhaust , intake changes.
A tuner may improve low end by playing with ignition timeing advance.
What is done with any specific setup may make a difference but be awhere you can't much feel any power improvement less than 10 hp.
10 hp gain in the 2500 rpm range will be hard to generate where you drive most.
Depends on your expectations and pocket book thickness.
Just some overview for you to consider.
Good luck.
Old Mar 19, 2013 | 04:07 PM
MIKE 04 GT's Avatar
MIKE 04 GT
Super charger, Turbo, ( dont think they make one for the 5.4 f150 so it will have to be costom, Or Heads, and cam. Non of these are cheap, Probley start around $2,500 Either route you go.
Cheap modes will be the gotts mod. Cheap some say they tell a differance, I did it and cant tell much if any differance. (It is basicly the same as a COld air intake)
Tuner, Some gains there
Longtube headers, you will get some gains, not sure how much,
Underdrive pullys Little gains
intake spacers, no gains there.
Electric fans, will get you some gains, but i dont think they are really worth Being less dependable.( Electric fans go out more often then mech clutch fans.)
Pretty much power is very expensive,
If it is cheap it probly not worth the hassle, or is not dependable
wa-sleeper
1997 - 2003 F150
Aug 22, 2015 11:09 PM
dwrestle
Apr 19, 2006 02:52 PM
johndeerefarmer
Computer Chips & Tuners
Mar 10, 2005 10:55 AM
JAYW
1997 - 2003 F150
Jan 20, 2005 02:15 PM
Rondeisel
Nov 8, 2004 11:11 PM
