coil is built into that dizzy , it's GM design HEI igntion , cap,rotor,coil,module are stock GM parts.
remove your coil check original wire for coil most likely not 12v you will need to by pass the resistor wire (behind speedo panel ) or use a relay to get full 12v to new dizzy .
i have one of these on my F100 works great
thank you, also is there any place cheaper than lmc truck to get he new rad support and inner fnders? and how many degrees before TDC do i need to have it firing?
Can also be done with a OEM duraspark distributor and a HEI unit from any parts yard or parts house with wiring. I ran it on a 390 and would say, yeah cheaper than ford box and ran just fine.
