Swing by a parts store and have them test your alternator and batteries. Most will do it for free.
Since the light goes out when you are at idle then your alternator could be failing either low voltage when RPMs increase or over voltage which usually means the voltage regulator is dying or dead. If that is the case then get it fixed before it fries your batteries.
