Injector o-ring replacement
Old Mar 18, 2013 | 07:35 AM
fd1109's Avatar
fd1109
Is there a thread on replacing the o-rings on the injectors and how to prevent hydro lock ? Thanks
Old Mar 18, 2013 | 01:51 PM
ggirten's Avatar
ggirten
I used a small shop vac to suck the excess oil out of the cylinder before I reinstalled. I have used this method at least 3 times without any problems.
Old Mar 18, 2013 | 02:16 PM
Tugly's Avatar
Tugly
Quite the spirit of adventure there: Fuel, oil, electricity, and sparks.
I chose a different route: Mity-Vac. The tube is the wrong size, but I inserted a smaller tube in the Mity-Vac tube... which just so happens to fit in the cup hole, the glowplug hole, and the HPOP reservoir hole.
After the injectors are in and torqued down, leave the GPs out. Lay the valve covers over each head and loosely thread a couple of bolts on each one. You can then short the starter relay on the passenger fender (key at least 6 feet from the ignition and 42-pin connector unplugged) and let the starter turn the motor with the glowplugs out (about 3 runs of 10 seconds each). If you have a sense of adventure and lots of time to clean oil off the walls, ceiling, yourself, the family dog, etc... leave the VCs off when you turn the motor. Either way, the fluids are outta there and coming soon to an exhaust pipe near you.
Old Mar 18, 2013 | 07:46 PM
Christof13T's Avatar
Christof13T
You should get out approximately 1 regular Gatorade bottle worth of oil. I used mity-vac and left my vc's on the surgery table when i purged... pretty oily mist cloud! No walls or ceiling to worry about... and the oil is great for my complection... lmao
But yah... x2 on what rich said... i think shop vac + stuff that catches fire = expensive bad day waiting to happen. Mity-vac kit is like 35$ at harbor freight.
whitetmw
Mar 18, 2015 10:02 PM
Jerry Chaney
Jan 16, 2014 11:15 AM
ve7kilohertz
Jun 30, 2012 01:12 PM
consol
19
Jan 3, 2012 11:52 AM
69 stang
Jul 1, 2009 10:02 PM
