o-ring replacement
Old Jul 1, 2009 | 11:29 AM
69 stang's Avatar
69 stang
o-ring replacement
pulled my injectors today and i got some oil down in the rear cylinder. what is the best way to get it out? i was thinking to turn the motor over with rags over the injectors holes to catch the oil. will that work or do something different.
Old Jul 1, 2009 | 11:33 AM
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
With injector out, suck the oil/fuel with a vacuum, larger syringe, etc.
Otherwise, you need to install the injector, remove the glowplug and with the valve cover bolted down (important if you don't want to squirt oil 20 feet from the truck), crank the motor over to purge oil out the gp hole.
If you try to crank it over with no injector, you'll just pump huge amounts of fuel and oil into the cylinder.
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
Old Jul 1, 2009 | 11:43 AM
69 stang's Avatar
69 stang
thanks for the advice. i'll use the syringe
Old Jul 1, 2009 | 01:20 PM
79f-250custom's Avatar
79f-250custom
id put the injector in and take the GP out and crank it. its so much faster. i did the syringe and if you have alot of oil in there its going to take a long time.
Mitch
Old Jul 1, 2009 | 10:02 PM
69 stang's Avatar
69 stang
so in turning over the motor with the glow plug out. how would i know if all the fluid is out of the cylinder?
