89 f150 stalling problem
Old Mar 18, 2013 | 02:34 PM
Leland337's Avatar
Leland337
Unplugged coil used a volt meter while my friend cranked it over found the wire with voltage. The one on coil end of connector put power to the wire that had voltage had keys removed Started then cut out same way as always
Old Mar 18, 2013 | 02:35 PM
Leland337's Avatar
Leland337
Is there a sensor that would tell computer to cut off spark?
Old Mar 18, 2013 | 02:42 PM
Leland337's Avatar
Leland337
Already spent about 800 $ in parts would hate to give up now
Old Mar 18, 2013 | 08:17 PM
Leland337's Avatar
Leland337
Anyone else have any ideas
Old Mar 18, 2013 | 09:37 PM
montey09's Avatar
montey09
I have the same problem with mine. i was thinking about replacing brain box.
Old Mar 18, 2013 | 10:13 PM
montey09's Avatar
montey09
Old Mar 18, 2013 | 11:02 PM
Leland337's Avatar
Leland337
I was told if the computer was bad it would not even start as that controls injectors and ignition spark
Old Mar 19, 2013 | 04:16 PM
Leland337's Avatar
Leland337
Thanks for all the help so far. Does anyone know of anything else I could try.
Old Mar 19, 2013 | 06:29 PM
Truckin Bob's Avatar
Truckin Bob
ABSOLUTELY WRONG !!!!
A failing computer CAN allow the truck to start, run and then die.
Here's a little something to read:A9x ECM's (and same years ECM's) Failures Due to Age
Take some time and remove the PCM and look inside for leaking capacitors/burnt components.
I'll bet that's what you're chasing.
I thought I posted this earlier but I must have hit "preview post" instead.
Bob
Old Mar 19, 2013 | 07:34 PM
Leland337's Avatar
Leland337
Thank u so much for this info and great photos. Will pull the ECM tomorrow morning and let u know the results.
Old Mar 19, 2013 | 07:37 PM
Leland337's Avatar
Leland337
Just to make sure the ECM on a 89 ford f150 5.0 is an the drivers side behind the kick panel. Is this correct
Old Mar 20, 2013 | 12:22 AM
Leland337's Avatar
Leland337
Anyone know the ecm location
geoasis
20
Mar 26, 2015 02:46 PM
bowling1
Aug 24, 2014 07:37 AM
Larry horne
Nov 6, 2008 12:57 AM
bhuff
Aug 15, 2008 04:32 PM
