I have a 1989 F250 XLT 351W (EFI) 5 spd manual 4X4, 155,000 miles.
I have a problem with the truck dieing, mostly in the summer time after I have driven it for miles, cut it off and let it set. It usually starts up and runs 1 block and dies. Fires up after alot of cranking and the drives 1 block and dies. Fires up after more cranking and usually will run there after. I have thought fuel vapor lock but I thought electric fuel pumps circulated the fuel for cooling purposes so I'm thinking distributer ignition pickup. I've replace all 3 fuel pumps and fuel filter and pressure regulator.
I tried to install the new ignition pickup last month (module on side of distributor has been replaced, NAPA on side) and ran into a couple of problems. I took the cap and rotor button off but could not disassemble it any further. What is the secret. I am trying to do this with the distributor installed. How does this thing come apart?
