Steering linkage question
Old Mar 17, 2013 | 10:16 PM
Artagra's Avatar
Artagra
Dang it...I meant "Shift" linkage...
I am running a Chevy 350 (PO started it...) with a TH350 tranny. I have installed the Toyota PS and a GM steering column with column shift. I have purchased a Lokar shift linkage. I am also still running the factory brake setup.
The problem I am having is the linkage and the arm at the base of the steering column do not line up...not even close. The amount of angle that the linkage rod has to be causes a serious binding issue. I have an idea as to what to do to extend the column arm but was wondering if anyone has any pictures from a similar setup for what you have done to fix this issue.
LSJUNIPER
Apr 27, 2011 04:54 AM
pukey
Dec 31, 2010 04:21 PM
rmoore7167
Jan 13, 2007 05:20 PM
workingdog
Jun 15, 2006 04:28 PM
tojoski
Sep 18, 2003 01:09 PM
