Sponsored by: Real Truck
Something crazy happened yesterday.
Old Mar 18, 2013 | 11:33 PM
King-bRanch's Avatar
King-bRanch
The Steering Stabilizer seems to be a common culprit from what ive read on this Forum & in my experiences on Crotch-Rockets that DONT have a Stabilizer (mostly Honda's ) something similar happens if u dont re-plant the front wheel just right. Seen it happen once & also on numerous video clips...Ouch
I guess what iam saying is the S.S. would be my 1st check & if u feel the need to ride a Super Bike make sure it says "GSXR" on the side
Old Mar 18, 2013 | 11:42 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Tankslappers... I always felt the Kawasaki ZX7R was the most stable one of the bunch,
Josh
Old Mar 19, 2013 | 10:05 AM
King-bRanch
Bullitt....Now were both a "Thread HiJacker"
I hope i dont get a "label" now
Old Mar 19, 2013 | 10:41 AM
Bullitt390's Avatar
Bullitt390
Well... Death Wobble is just Superduty speak for tank slapper.
I embrace my forum title... Keeps things interesting
Josh
Old Mar 19, 2013 | 10:46 AM
2006lariat's Avatar
2006lariat
I would really look at that track bar. The bushing on the frame mount wear's, (if their is a Fuel leak from the pressure regulator, it run's down to the track bar frame mount) and it is just a ball joint on the axle, remember that Bushing, and 1 ball joint keep the axle under the truck.
(The truck the OP was asking about is an 05)
After that I would look at Ball Joint's, Drag Link, and Tie Rod ends. Obviously check Tire Pressures.
Old Mar 19, 2013 | 10:48 AM
King-bRanch
Josh
You are Right which is why i brought it up
I for one like your "title" only brought it up cause it made me laugh
Old Mar 19, 2013 | 10:53 AM
Bullitt390's Avatar
Bullitt390
It was Thread Terrorist, but that didn't go over well.
Josh
Old Mar 19, 2013 | 11:17 AM
RPM371's Avatar
RPM371
I've heard of the Death Wobble, but like everyone else had never seen it. I have seen something similar from tires that weren't balanced right and big trucks with autobalancers. All it took was a bump to set it off.
Old Mar 19, 2013 | 10:52 PM
droldsmorland's Avatar
droldsmorland
Originally Posted by FM FordFan
I checked under the truck and found the oil seals are out on both sides of the axle. I'm going to assume the bearings are going out or are out. I will have to get it to the mechanic to see how bad it really is. Thanks again guys for all of the great advice.
As others have mentioned the large black rings that you see flopping around are the outer dust seals meant to keep large debris out of the tube. Its common practice to cut them off and not worry about them unless your a hardcore off roader. In that case I believe there is a improved design that can be installed. Most dont bother with it unless they are in there repairing something else which would require axle removal.
Paratrooper84
6.7L Power Stroke Diesel
112
Jan 11, 2022 06:37 PM
Pele
Oct 13, 2014 12:38 PM
David7.3
Sep 18, 2014 12:31 PM
Butch(OH)
Jul 6, 2013 11:13 PM
chapinmesa
Jul 28, 2009 04:52 PM
