302 rod caps
Old Jun 2, 2003 | 07:12 PM
EricB's Avatar
EricB
302 rod caps
I just did a ring job on a 79 302 and i think I might of put the rod
caps back on either out of order or backwards,becuase the engine is extremly tight,any suggestions?
Old Jun 3, 2003 | 01:23 AM
baddad457's Avatar
baddad457
302 rod caps
The rods and caps are all numbered in sequence ( 1 thru 8) The #'s are stamped on one side of the rods and caps on the flat surface next to where they mate. All #'s must match each other and all #'s have to be together ( same side of the rod) all the # side of the rods have to face the outside of the block and corellate to the cylinder they go in. Cylinders 1-4 are on the passenger side of the block, front to back ( block facing upright) Cylinders 5-8 are on the drivers side front to back. Take your motor apart and start over. If you can find one, get a Motor's repair manual, I have one from 1964 to 1970 and it explains all this. Or get an engine rebuild manual. Main caps are also #'d ( or should be ) 1 thru 5 and fit in the block from front to back, there's an arrow cast into each, and the arrows should face to the front of the block
Old Jun 3, 2003 | 09:11 AM
EricB's Avatar
EricB
302 rod caps
thats what I thought,just about got it tore back down,tough way to learn
Thanx for your reply
Old Jun 4, 2003 | 08:23 PM
baddad457's Avatar
baddad457
302 rod caps
anytime, just ask and I'll try to help
JaysRanger
Oct 30, 2009 11:48 PM
79FordBlake
Dec 5, 2007 09:20 AM
deputy
Jul 18, 2007 08:35 PM
rusty70f100
Dec 4, 2005 05:36 AM
theonlybull
Sep 15, 2002 01:14 PM
