302 Long Rod
Old Sep 12, 2002 | 10:21 AM
theonlybull's Avatar
theonlybull
302 Long Rod
Old Sep 12, 2002 | 10:31 PM
Ford Truck Racer's Avatar
Ford Truck Racer
302 Long Rod
Was wondering if any one knew what you have to do to a 302 to for longer rods. I have seen 2 different types of rods longer than the 5.090 stock length. There is the 5.400 used in 347 strokers, a 5.155 length and the there is the longer 289 rod. Has anyone done this. I am looking for running 9.5 to 10. compression in a 58cc combustion chamber with hypertectic pistons. Thanks for any help.
Old Sep 13, 2002 | 05:27 PM
JTY's Avatar
JTY
302 Long Rod
I believe that longer rods require shorter pistons, or a stroker crank.
Old Sep 13, 2002 | 11:00 PM
54_5star's Avatar
54_5star
302 Long Rod
Try kb-silvolite.com. They have a good selection of pistons and have very good info concerning rod length, compression height, and compression ratio. Look under the Keith Black automotive section. The 289 rod is 5.155. The 5.155 rod was also used in the Boss 302 but it was a little beefier I think and had 3/8" rod bolts instead of 5/16".
Old Sep 15, 2002 | 01:14 PM
Quantrex's Avatar
Quantrex
302 Long Rod
289 rod is indeed is 5.155", the stock (non-Boss) 302 rod is 5.09" and shares small rod bolt size with the 289 rods. The 289HP/Boss 302 rod is 5.155" and has 3/8" rod bolts. Using 5.155" rods in a 302 requires Chevy 350V8 compression ht. (approx 1.54") pistons. Using longer aftermarket 5.4" rods requires a 1.30"/1.31" compression ht. piston. For a really long-rod setup, turn the rod journals to 2.10" and narrow the big ends of a set of Chevy 5.565" 400V8 rods with a set of 1.13/1.14" compression ht. pistons. The Ford piston pin diameter is .912" and the Chevy's is .927".
Aerostar
Aug 21, 2024 11:23 PM
bradphx
67
Jan 10, 2024 06:12 PM
miko6810
Modular V10 (6.8l)
Jun 4, 2014 06:14 AM
Oklahoma Chapter
Apr 11, 2003 10:33 PM
walterdanek
16
Feb 16, 2001 07:56 PM
