Bouncing voltmeter
Old Mar 16, 2013 | 11:24 PM
Dieseltillyoudie's Avatar
Dieseltillyoudie
Bouncing voltmeter
Howdy y'all, I have a 1986 f250 6.9 diesel with an aftermarket ats turbo and a 4 speed manual. Recently I found that the in-cab volt meter is pulsing during normal driving, as do the head lights and dash lights. However, when I first start it, the needle is steady, then after about 30 seconds it begins to bounce. I had the alternator and the batteries tested and they both passed. Furthermore, I have the tachometer sensor completely disconnected but the tach is still faintly getting a signal. I think the two problems are related....any suggestions??
Old Mar 16, 2013 | 11:47 PM
akamacgyver's Avatar
akamacgyver
Clueless spectator!
Do you think possibly your gp's are cycling? That is the only thing that I can think of on our trucks except the starter that would draw enough amperage to bounce the needle or cause the lights to surge. You could get it to normal operating temp, disconnect the power to your GPC, and see if it still does it.
BTW welcome to the forum.
Mac.
Old Mar 17, 2013 | 02:06 AM
Dieseltillyoudie
That could be it, I did forget to mention that when the glow plugs are cycling, the needle stays steady, but when they are off it goes back to bouncing. How would I disconnect the glow plugs??
dclack
Dec 21, 2011 10:40 PM
6litrefan
Sep 20, 2009 01:47 PM
bradsamcarp
Jan 18, 2008 03:41 PM
fbca7
15
Feb 6, 2007 10:19 PM
Greenscape
Jan 31, 2005 02:37 PM
