never starts on the first try
Can anybody help. I drive a 06 350 and the dam thing will never start on the first go in the morning it just turns and turns. After I stop and cycle tbe glow plugs some more it starts right up. It almost feels like a fuel problem or somthing. Any thoughts would be appreciated.
You need to get a set of gauges that reads live data like scan gauge II or something similar so you are not flying blind. It could be the FICM is on its way out. If you look in the tech folder there is a FICM test procedure that will show you how to do it with a digital volt meter, Anything less than 45 volts at anytime during KOEO, cranking, idle or WOT or anytime in between indicates a failing FICM.
Probably codes kicked on from all that cranking. Maybe its just that cold that the cylinders need that extra cycle of heat from the glow plugs to get going. Also try using a synthetic oil. I use AMSOIL in mine. When it gets cold here in Iowa my truck cranks over with no drag plus I plug it in. The Powerstroke definately does not like the cold. lol My motor sounds like its gonna throw a rod when it colds out and it hasn't been plugged in. Sorry can't help you more...
Like data when you try to start would be nice. ICP (Injection Control Pressure)
Is one of the first ones to be looking at and the FICM voltage.
A nice tool to have if you don't have one is the SGII ScanGaugeII : Linear Logic - Home of the ScanGauge
Just ask about programming the Xguages and someone will help.
Sean
Sean
