broken push rod
Old Mar 15, 2013 | 06:23 PM
justblowin'smoke's Avatar
justblowin'smoke
broken push rod
So I have an early 99 broke a push tube just wondering other than replacing it what I should check valve seems fine all other tubes are fine should I be worried that I can't get a very small piece out can't find it. Got both larger pieces out rocket looks good it happened right after sitting all winter warmed up and I got on it running upwards of 100mph and let off and hit exhaust brake to slow down
Old Mar 15, 2013 | 07:15 PM
Crewcab Turbo's Avatar
Crewcab Turbo
Not sure about what else to look for. Is the piece steel or aluminum? Have you tried a telescoping antenna with a magnet on the end and try finding the piece down the hole? I'm sure others here will know more. Good luck. I drove Sycamore while working today.
Old Mar 15, 2013 | 08:42 PM
justblowin'smoke
Yes that's how I got the two larger pieces out but have yet to be able to get the smaller piece out bought new ones thru riff raft diesel so hopefully once they show up it'll be fine
I actually need to update that I'm west of Hampshire now
Old Mar 15, 2013 | 09:45 PM
snakedoc's Avatar
snakedoc
if you where doing 100mph you where high on the rpms, and then treid to slow it down with the exhaust brake you may need to replace the all.
just fish out what you can and dont worry about them.
Old Mar 15, 2013 | 10:39 PM
12pump's Avatar
12pump
You can use a shopvac. Just duct tape a piece of tubing to the end of the shopvac tube and you are all good.
Old Mar 16, 2013 | 07:36 AM
F350-6's Avatar
F350-6
With those RPM's and the exhaust brake, I'd pull them all out and roll them across a table to be sure no others are bent. If they're straight, stick them back in. If they've got a warp to them, replace.
Remember which end goes up.
Old Mar 16, 2013 | 07:58 AM
Crewcab Turbo
Not only which end goes up but also keep them in the same location/cylinder. They wear and you want to keep them where they have been for the last 100k+ miles.
Old Mar 16, 2013 | 08:54 AM
mueckster's Avatar
mueckster
With stock push rods, install the copper end up.
Old Mar 17, 2013 | 01:47 PM
justblowin'smoke
Will do was planning on pulling couple more to check them
gittinwidit
Nov 28, 2018 05:20 PM
MConnelly
Jan 2, 2012 07:58 PM
Peter94
The Next Generation
Jul 28, 2009 04:04 PM
Green_Dually
Garage & Workshop
Sep 7, 2007 11:49 AM
MatthewC
Garage & Workshop
Apr 11, 2005 05:55 PM
