Engine install attemp
Old Mar 15, 2013 | 09:00 AM
68cabby's Avatar
68cabby
Well..was out wrestling my 300/6 into the truck last night. No success and decided to call quits at 11 pm. The input shaft of my t18 just wasn't lining up right and causing a hangup every which way. Little discouraged right now. I gotta take the transmission out now and mate both out of the truck. I had an inch to go and it woulda been there!
Old Mar 15, 2013 | 09:04 AM
HIO Silver's Avatar
HIO Silver
Acting like a high school girlfriend eh? Keep at it!!!
Old Mar 15, 2013 | 09:12 AM
Gembone's Avatar
Gembone
Can be a real pain if the angles don't match.
It can be a lot easier if done outside the vehicle.
With as much room as these trucks have it's just as easy to poke them in already combined.
You can get it, just keep at it.
Old Mar 15, 2013 | 09:22 AM
68cabby's Avatar
68cabby
Yea..its being one of those stalker type of girlfriends that you can never get rid of
Thanks guys. I guess I'm not as Bummed bout having to pull the tranny..just that its another thing I gotta do just to get back to square one. All I gotta do is drop the crossmember and were good. Driveshaft is already loose sms were gonna pull it through the front seeing as how I have no front clip.
Old Mar 15, 2013 | 09:32 AM
MavSprint's Avatar
MavSprint
Maybe the clutch disk isn't lined up right?
Old Mar 15, 2013 | 12:57 PM
68cabby's Avatar
68cabby
We've put an alignment tool in it and it does fine
Old Mar 15, 2013 | 02:12 PM
MavSprint's Avatar
MavSprint
If you have an alignment tool, then I'm sure you also put the transmission in gear and rotated the tail shift to line up the input shaft spline with the clutch disk.
Wouldn't think it would be necessary for a standard transmission, but to install an automatic I found it helpful to make some alignment pins by cutting the heads off two bolts and cutting a screw driver slot (for removal) in the ends.
Old Mar 15, 2013 | 03:50 PM
68cabby's Avatar
68cabby
Yes we rotated the Driveshaft and used the alignment pins. That's why we are so stumped and why I'm resorting to taking the tranny out. It would go in until the last 3/4 of an inch or so but no more..
Old Mar 15, 2013 | 03:59 PM
redroad's Avatar
redroad
Having the front clip off is the only way to go .. From what you describe you lack the pilot bushing is all .. Maybe there's I.D. to O.D. mismatch on the pilot bushing ? or angle as has been mentioned .. H.S. girlfriends always complain about that
Old Mar 15, 2013 | 05:01 PM
68cabby's Avatar
68cabby
Haha then its taking a very tricky angle.! The alignment tool goes in all the way and its the same size as my input shaft. You guys crack me up!
Old Mar 17, 2013 | 09:17 PM
68cabby's Avatar
68cabby
It was the pilot bushing! After going back Saturday and having the clutch off twice..the bushing was wrong. Halfway through the bushing was smaller than the input shaft so it was only allowing a little bit. Soo after 2 hours the engine is in (as of Saturday)
Old Mar 18, 2013 | 01:44 AM
Bart8109's Avatar
Bart8109
Congrats. Have had that problem myself a time or two. HS girlfriend thing not the pilot bearing thing
mrblonde108
Jul 1, 2012 07:03 PM
snurtle112
Jan 28, 2008 12:27 PM
fishmanndotcom
Offroad & 4x4
Oct 10, 2007 06:57 AM
Waves
1983 - 2012 Ranger & B-Series
Jul 22, 2007 12:16 PM
hoxiii
Offroad & 4x4
16
Jun 29, 2004 02:44 PM
