Block and head casting numbers
Old Mar 15, 2013 | 07:56 AM
alchemist1's Avatar
alchemist1
I'm trying to find out the exact year of my 390 (should be 67-69) that is in my truck. Where does Ford put indentifiers on their motors (block and heads), of this vintage?
Old Mar 15, 2013 | 11:30 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Look behind the starter for the block casting #'s, and as far as the heads here is a copy and past about a 460....
If the heads were cast in the '70s (and possibly the early '80s), it most likely will be a D3VEA or similar number. D2VE, D0VE are common early '70s numbers (stay away from D2 heads, by the way.) It will be between the spark plugs.
If the heads were cast in the '80s, the numbers will be on the underside of the head, on the lip that extends past the block and over the valley.
If the heads are off the block, turn them upside down and you will see them.
If they are still on the block and you have the intake off, use a mirror to read the lip, the underside of the heads. I used a dental mirror.
Old Mar 15, 2013 | 12:13 PM
montana_highboy's Avatar
montana_highboy
There are no markings on a FE block that will identify the specific production year, e.g. a "C6ME-A" casting number could identify a block as a '66 but it could also be found on any FE block cast from '66 through '72
Old Mar 15, 2013 | 12:30 PM
77&79F250's Avatar
77&79F250
Mont HB....Well I figured after 122 views of this thread and no help from anyone, I would give it a try, thanks for the back up on the FE buisness.
Old Mar 15, 2013 | 12:35 PM
montana_highboy
No problem Rich, at least you bumped the OP's thread to the top so he could get an answer
Old Mar 15, 2013 | 02:01 PM
montana_highboy
Is the engine I.D. tag still intact?
I.D. Tag Information -- The Ford V-8 Engine Workshop
Old Mar 15, 2013 | 04:01 PM
mikeo0o0o0's Avatar
mikeo0o0o0
I believe there is a casting date code on FE's just below the oil filter adapter. But that's going to be the date the block was cast, not the date the engine was built. I don't know how much of a lag there was between casting and building.
It's not too clear but you can kind of see the location in the picture. Here, because the engines upside down the mark is on top of the adapter
Old Mar 15, 2013 | 04:38 PM
montana_highboy
Good question Mike, i wouldn't think the blocks sat around for too long between casting date and build date, but i honestly have no idea, were they promptly shipped off to Ford engine assembly plants or did they sit around the foundry for awhile...
Old Mar 15, 2013 | 04:54 PM
77&79F250's Avatar
77&79F250
I bet ol ND knows that answer, even though he was a parts counter guy and not assembly line guy? Unless I am wrong on that guess too?
I guessed wrong once before, but in the end and 20 years later I retired out of the Army, so that guess was not all that bad.
Old Mar 15, 2013 | 10:30 PM
montana_highboy
Thanks for your service my tour was no where near as long as yours, i served 4yrs with the Army during the first Gulf War.
Old Mar 15, 2013 | 10:49 PM
77&79F250's Avatar
77&79F250
No need to thank me you was there too, so thank you, but thanks for the thanks.
Oh yea Desert Shield and Storm I was there with 3rd AD out of Germany, in a aviation unit flying Blackhawks as a crewchief and door gunner.
over
Old Mar 15, 2013 | 11:05 PM
85e150's Avatar
85e150
Casting numbers give you the year of revision. As per prior post, you might see a C6AE or C7AE in '68 or 69. You will see a D2TE head casting code clear into '76 iirc.
There is a date code on the block near the oil filter adapter area.
Extreme close up:
http://www.fordification.com/tech/im...k-datecode.jpg
Again, as per the prior post, that is not the day it was put together and installed. A 6 month lag might be about right.
Bigger picture:
Ford 352, 390, 406, 427 and 428 Engine Blocks
Serving suggestion: Don't worry too much about it. The numbers and date code will not make your vehicle a priceless classic.
To those in the armed forces: Thank you for your service.
Old Mar 16, 2013 | 03:10 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
I'm trying to find out the exact year of my 390 (should be 67 -69) that is in my truck.
None.
Casting numbers are foundry marks, are WORTHLESS for ID'ing the engine sizes or what vehicles/years the parts were installed in.
Casting numbers cannot be cross referenced to Ford part numbers.
360/390: 1968/76 F100/350. 1965/67 F100/350's were only available w/a 352.
1968/71 F100/350 360/390 heads have a C8TE casting number prefix, 1972 is D2TE.
1968/72 360/390 block casting number prefix is C8TE.
Date codes on blocks are foundry marks for the year/month/day they were cast. Then the blocks are placed outside to "season."
Then these rough blocks are sent to engine assembly plants to be finished. Next, the completed engines are sent to car/truck assembly plants where they are "banked" until needed.
So, it could be 3-12 months from the day the blocks were first cast, before the completed engines were installed in vehicles.
Late 1973, early 1974: 1st Arab Oil Embargo occurred. Sales of vehicles with 'gas guzzler' 351C/360/390/400/460 engines fell off considerably. People, for the first time since WWII, were concerned about MPG
Old Mar 17, 2013 | 05:01 PM
alchemist1's Avatar
alchemist1
Thanks guys. The 390 engine is from a Fairlane, somewhere between 66 and 69. The code near the oil filter adapter is C6AE.
Old Mar 17, 2013 | 05:08 PM
montana_highboy
Date codes on blocks are foundry marks for the day they were first cast. Then the blocks are placed outside to "season."
Excellent info ND, as usual... i'd send reps but the FTE gods won't let me.
