What am I doing wrong?
Old Mar 14, 2013 | 01:52 PM
sa-jimd's Avatar
sa-jimd
Folks,
I'm working on an '89 F250 with a 351W. It was having low fuel pressures issues, so I replaced filter. That didn't make any difference so I replaced the high pressure fuel pump. It ran for about 5 minutes before the pump quit. It showed about 5 psi. Next, I replaced the fuel pressure regulator and the fuel pump. Still only 5 psi. I checked the voltage at the pump and it was 12V. I know the pumps started out OK with about 5 ohms but now they both show open circuits. They are Airtex pumps, so... are Airtex pumps junk, or am I causing the problem?
I sure would appreciate some help with this.
Jim
Old Mar 14, 2013 | 03:26 PM
Lead Head's Avatar
Lead Head
I've heard of issues with Airtex pumps before. You replaced the in-tank pump as well?
Old Mar 14, 2013 | 06:00 PM
sa-jimd's Avatar
sa-jimd
No, I didn't replace the tank pumps. I suppose I could turn them on for a couple seconds and watch the fuel line, but I can very clearly hear them turn on for a couple seconds when I turn on the key.
Old Mar 14, 2013 | 07:12 PM
rla2005's Avatar
rla2005
Post # 2 in this thread will show you how to turn the fuel pumps on full time: https://www.ford-trucks.com/forums/1...ump-relay.html
Old Mar 14, 2013 | 09:20 PM
sa-jimd's Avatar
sa-jimd
Yep, I keep a piece of wire under the hood so I can jump the fuel pump anytime after all, it's 24 years old. I also keep a pressure gauge on the fuel rail. I guess I'm not doing anything wrong here. Airtex just has a serious quality control problem. I'll take it back and get a third pump, but it doesn't inspire much confidence. Maybe I can exchange it for another brand.
Thanks for the help
Jim
Old Mar 14, 2013 | 09:34 PM
JWC 3's Avatar
JWC 3
Not just Airtex . Many are crap . I worked untill 9pm one night putting fuel pumps in patroll cars during Bonaroo . 5!! went that day ! The heat , crappy fuel , and substandard parts . Oh, I also put 3 alt,s on my friends car , ALL from GM !
Old Mar 14, 2013 | 09:54 PM
bluemtn95ford's Avatar
bluemtn95ford
I replaced my pump with Bosch which I ordered from RockAuto online. It's been fine so far..
Old Mar 16, 2013 | 10:33 PM
Immortal_Ben's Avatar
Immortal_Ben
Bet it is the tank pumps.
Ford Bronco Man
1978 - 1996 Big Bronco
Aug 11, 2013 12:22 PM
dakota-boy
19
Feb 18, 2012 10:18 PM
v8xploder
Oct 12, 2009 05:46 PM
4X4 IN REFUGIO
Aug 31, 2006 02:36 PM
mrbooka
Feb 25, 2002 10:41 PM
