Fuel Filter Change
Old Mar 12, 2013 | 06:52 AM
MarkMoore's Avatar
MarkMoore
Fuel Filter Change
I finally got around to changing my fuel filter and I think the lower one, at least, was original (notice the difference in the bottom of the filter - they changed them in 2010 I think). They both looked pretty bad.
Since they're done, I have noticed better throttle response.
Old Mar 12, 2013 | 08:04 AM
JaySVX's Avatar
JaySVX
Ouch, good thing you got it done. Changing that lower one can be a bear. I had to buy the 37mm socket with 18" extension. Glad to hear you got it done.
Old Mar 12, 2013 | 08:29 AM
69cj's Avatar
69cj
For guys that still need to buy one it's 36 mm and the top one is 24 mm. Don't use the square drive to remove them use a socket. Sq. drive will break the cap.
Old Mar 12, 2013 | 08:33 AM
JaySVX's Avatar
JaySVX
Oops, you're right, I meant to type 36mm, must have fat fingered it. Thanks for catching it.
And for those that don't want to shell out for hte socket, you can't get at it with anything else, I've tried every tool in my garage, it's just not happening.
Old Mar 12, 2013 | 10:12 AM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
There's a specialty socket for this:
S3624, Socket, Filter Flip, 24 and 36mm, 3/8" square drive
For $32 it's not that bad, a 36mm spindle socket at Autozone was around $20 last time I checked. This might be the only time SO is cheaper than buying two Duralast sockets.
Old Mar 12, 2013 | 10:53 AM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Oil filter wrench... One that fits Fram PH8A or Motorcraft FL1A works perfectly fine on the lower cap.
That's what I used from 2003-2010 before I stumbled upon the Snap-on socket.
Josh
Old Mar 12, 2013 | 10:59 AM
Kayteg1's Avatar
Kayteg1
36 mm = 1 7/16"
Worth trying if you have big SAE set as those big sockets can get pretty expensive. I have box set, but the size jumps from 1 3/8 to 1 1/2
Anybody knows the torque?
Old Mar 12, 2013 | 11:03 AM
texastech_diesel
Token Redneck
Primary fuel filter cap is 19 ft-lbs
Secondary is 14 Nm/124in-lbs
Oil fiter is 14-22 ft-lbs
Old Mar 12, 2013 | 04:08 PM
svt1996cobra's Avatar
svt1996cobra
When I changed mine, I got a diesel bath!
David
Old Mar 12, 2013 | 05:55 PM
bismic's Avatar
bismic
You can get the 36mm socket for around $8
Old Mar 12, 2013 | 07:14 PM
vellingapa's Avatar
vellingapa
i wish, anyone ever have trouble getting the cap on the primary off. I'm anticipating problems next time I change filters as I when I put it on last time I had to oil the cap threads and over toruqe a bit (in the alternative cap gets tight to install if only changed bi-annually - not many miles now days) The time prior I had the dealer change the filter and they must have cross threaded or something as boy was the cap a bigger to put back on. Anyway I'm figuring it will require breaking to get off. Thought?. Of course I will make sure to have a replacement cap onhand next time I change but don't want to damage the housing in the process.
Old Mar 13, 2013 | 11:54 AM
ho_shi's Avatar
ho_shi
am new to all of this.... (self diesel serviceing that is) BUT i thought that when you bought the filter they came with a new cap?? or so all the oil services change places I have been to have told me.....
AJ
Old Mar 13, 2013 | 12:01 PM
bbender85's Avatar
bbender85
wondering about the primary filter... had a big breaker bar on mine trying to get it off and it was bowing i was reefing so hard on it, but i didn't want to break the cap so i gave up.
any tips on getting it off?
Old Mar 13, 2013 | 12:07 PM
MC5C's Avatar
MC5C
Some oil filters come with a new cap permanently attached to the filter element. They would be the bad ones, the dreaded NAPA oil filters, and woe betide anyone who uses one... Seriously, don't use them, use an OEM filter which snaps into the OEM cap. Same with the fuel filters, they snap into the OEM caps. Funny thing, I changed the oil filter on my wife's Mercedes a little while ago, and it was exactly like a 1/5th size version of the 6.0 PSD oil filter. If you took a picture with no size reference you would not be able to tell them apart, it is only about 2" tall and very cute.
Brian
Old Mar 13, 2013 | 01:20 PM
acf6's Avatar
acf6
Originally Posted by bbender85
wondering about the primary filter... had a big extension on mine trying to get it off and the extension was bowing i was reefing so hard on in, but i didn't want to break it so i gave up.
I used a oil filter wrench that i use for my coolant filter, and put it around the big part of the cap. Spun it right off. cant really use it to put it back on though
