decisions decisions
Old Mar 11, 2013 | 06:50 PM
Bulldawg1081's Avatar
Bulldawg1081
decisions decisions
I'm trying to decide which route to go on my truck, I have a 78 f100 with a 300 6cyl and a 3spd on the column which the PO put on the floor (which I hate) anyways my problem is the thing always gets hung up between gears at the worst times like at a busy intersection and I've had it with the thing so I'm trying to decide which would.be the easiest to do, convert to a 4 spd like an np435 or go with a c4 automatic.believe going with a 4 spd all i have to do is unbolt the 3spd off of the bell housing and bolt the other one up please correct me if in wrong.... what would be the pros and cons of going with an automatic or the 4 spd ? Please help me decide!
Old Mar 11, 2013 | 11:18 PM
85e150's Avatar
85e150
4 speed is the easiest. You may have to have your drive shaft "adjusted", but every thing else is pretty much bolt in.
Old Mar 12, 2013 | 07:34 PM
Bulldawg1081
Could I use the 3spd bell housing or would I have to use the 4spd housing?
Old Mar 12, 2013 | 11:29 PM
85e150's Avatar
85e150
Bell should be the same. Check your input length. The trans to bell will be the same, a rectangular "butterfly" pattern.
Old Mar 13, 2013 | 08:09 PM
Bulldawg1081
Sounds good, the 4 spd should be Alot more pleasant to drive! Thankyou for your help
thehickfarmer
Dec 20, 2018 09:55 AM
Chris 56 f6
Large Truck
May 19, 2014 06:25 PM
8bahead
Apr 5, 2008 05:33 AM
IdahoTower
1983 - 2012 Ranger & B-Series
Oct 6, 2007 07:13 PM
Kevin
Jan 2, 2000 06:46 PM
