at my ends
Old Mar 10, 2013 | 08:42 PM
towtruck boss's Avatar
towtruck boss
at my ends
I HAVE A 2002 F450 7.3 DIESEL I HAVE A PROBLEM I CANNOT FIGURE OUT MY TRUCK STUMBLES AND WILL NOT ACCELERATE AND HAVE THE HARDEST TIMES GOING UP A HILL I CANNOT CATCH SPEED ITS SHAKES SPUTTERS AND REFUSES TO GO. LIST OF THINGS I HAVE DONE IS CLEANED TANK NEW SENDING UNIT IN TANK NEW FUEL PUMP NEW FUEL FILTER NEW FUEL PUMP REGULATOR NEW VALVE COVER GASKETS ADN HARNESS NEW ICP NEW IPR I AM LOST AND DONT KNOW WHAT ELSE TO DO ALSO TOOK OUT ALL INJECTORS AND PUT NEW ORINGS ON THEM AND INJECTOR TEST SAYS ALL INJECTORS ARE GOOD ONLY CODE WILL SHOW UP IS LOW BOOST
Old Mar 10, 2013 | 08:48 PM
JOHN2001's Avatar
JOHN2001
Reading all that I was thinking you must have a big boost leak.... Then I read that it's throwing a code. Have you checked for boost leaks? Is there a lot of spot under the hood? Check all boots make sure there clean with no rips and tears and tight
snakedoc's Avatar
snakedoc
is the truck empty and will not go?
ether you have low fuel psi, low oil psi, no boost, bad injectors, low compression.
dose it start fast? does it blow smoke when you are loosing power?
i would check the fuel psi just to see where it is.
second i would check the hpop psi it may be weak.
Old Mar 10, 2013 | 08:58 PM
towtruck boss
I HAV LOOKED FOR LEAKS COULD NOT SPOT ANY I THOUGHT ABOUT CHANGING HPOP TODAY BUT WAS TOLD IT COULDNT MAKE MY TRUCK ACT UP LIKE THAT OR MAKE IT STUMBLE I KEEP GETTING TOLD FUEL HAS TO BE IT BECAUSE THE HILLS CAN TRIGGER IT EVERYTIME
Old Mar 10, 2013 | 09:01 PM
towtruck boss
IT DOES NOT SHOOT ANY SMOKE EVEN WHEN IT IS STUMBLING AND REFUSING TO GO DO YOU THINK IT COULD BE INJECTOR PUMP
Old Mar 10, 2013 | 09:04 PM
snakedoc's Avatar
snakedoc
no smoke i say your boost is fine, sounds like low fuel psi or low oil psi.
it could be the injectors, have you looked at the oil flow form them to see if some are weak?
JOHN2001's Avatar
JOHN2001
It could be anything. Fuel/air. You can't just look for a boost leak! Make a boost leak detector... Tell us a little more about your truck you have us limited information. Does it have gauges? If so what kind of boost are you making? Is it tuned? Have you checked fuel pressure?
Old Mar 10, 2013 | 09:32 PM
towtruck boss
how do you make a leak detector for boost
Old Mar 10, 2013 | 09:34 PM
towtruck boss
Wat do you think left that could make me have low fuel psi with all the things I have changed
Old Mar 10, 2013 | 09:37 PM
caedo's Avatar
caedo
I had the exact same symptoms as you, and considering you were messing around in the tank, my guess is that you made the same mistake as me. When I did my hutch mod I accidentally swapped my pickup line with my return line on the cap of the tank. Therefor I was trying to suck the amount of fuel a 3/8 hose could support out of a 5/16 line. Once I dropped the tank and switched the lines back, all problems were solved.
My $.02
Old Mar 10, 2013 | 09:43 PM
caedo's Avatar
caedo
https://www.ford-trucks.com/forums/1...ctor-pics.html
Old Mar 10, 2013 | 09:49 PM
clux's Avatar
clux
My $.02
That's a great piece of information, I would have never considered even the possibility of that happening.
Reps.
Old Mar 10, 2013 | 09:51 PM
caedo's Avatar
caedo
Thanks, it threw me in the ringer for a while as well. I figured at least it would be another possibility for the OP to check off.
Old Mar 10, 2013 | 09:54 PM
BigAlsPSD's Avatar
BigAlsPSD
Is the line going to the MAP sensor connected? What is the code specifically?
Can you view live data? Look at the MAP and Manifold gauge pressures.
Old Mar 10, 2013 | 10:35 PM
Bonanza35's Avatar
Bonanza35
Subcribing, just up hill or all the time?
