Replacing heater core
Old Mar 10, 2013 | 10:19 AM
Rob Cuenin's Avatar
Rob Cuenin
Thank-you
Old Mar 10, 2013 | 11:28 AM
ranger429's Avatar
ranger429
If you go to a really good parts store they can look in the back of their catalogue and find you a manually operated heater control valve where you can run your own cable. Plenty of older model cars used that style from the factory.
Originally Posted by chesire17201
BUT if you do put a valve in, then yes, you need some form of bypass before it for the coolant to keep flowing when the valve is closed, or all you are doing is shutting the entire cooling system off because it won't be able to flow through the radiator to cool, it will be stopped at the valve, probably messing up quite a few things, and eventually overheating.
There is no harm in stopping the flow of water to the heater core and it certainlly will not stop the flow to the radiator.
Old Mar 10, 2013 | 11:47 AM
Rob Cuenin's Avatar
Rob Cuenin
I'm going to look into a manual valve maybe something I can put like a hand choke to it to control it .Thanks
ramarado
Nov 22, 2008 10:59 PM
rsulvan
22
Mar 29, 2007 12:24 AM
Low70Ford
Dec 23, 2006 11:11 AM
Jameshuden
17
Mar 10, 2006 05:40 PM
Frank Kistner Sr.
Aerostar
13
Feb 3, 2005 03:32 PM
