need 400 crank kit
Old Mar 9, 2013 | 04:52 PM
ford 400 outlaw's Avatar
ford 400 outlaw
need 400 crank kit
i need a crank kit for my 400 which is the best one to get and how much should a good one cost
Old Mar 9, 2013 | 04:54 PM
85e150's Avatar
85e150
AFAIK, this is as good as it gets:
TMeyer, Inc. Precision Automotive Machining
Is your crank wiped out? If your crank and rods are good, you only need those pistons he shows.
Old Mar 10, 2013 | 09:15 AM
ford 400 outlaw
yes crank is wiped out rods are good just need crank itself and rod and main bearings
Old Mar 10, 2013 | 09:29 AM
J ballan's Avatar
J ballan
How bad is it? Could they grind the crank and install under sized bearings? The junk yard may be the cheapest place to start looking. Also the engine shop around here keeps a lot of good used parts. Check your local engine shop they just might have a good used one around. Good luck.
Old Mar 10, 2013 | 11:02 AM
ford 400 outlaw
already have motor in shop and his crank guy said it was too far gone...had already already been a .30 over crank kit
Old Mar 10, 2013 | 11:49 AM
V10man's Avatar
V10man
Rockauto.com has them ranging from $208 - $300 with core.
PurelyFord
32
Jan 25, 2019 12:00 PM
jonbass40
Oct 30, 2008 10:49 PM
coolmint94
Feb 18, 2004 09:55 AM
skud
Jan 21, 2002 09:39 PM
mimsand
Sep 13, 2001 10:32 AM
