Starter acts up on cold days
Old 03-09-2013, 03:01 PM
Rose Clifford's Avatar
Rose Clifford
Rose Clifford is offline
When ever its cold at night (20F ish) I cycle my glow plugs twice for good luck, and turn the key. Almost every time, the first start just spins the starter without engaging the flywheel. It sounds like it tries, and makes a quick grind sound, but never engages on the first try. Second try, it works every time. What gives? Batteries, alternator, and the solenoid on the starter were all replaced in the last year....as well as the lug connecting the 0/0 red wire to the starter.
It's been doing this for a long time, even before I replaced everything mentioned above. I've been hoping I don't need to replace the starter itself, because like I said it works 99% of the time and only does this on the really cold starts.
Next cold day I'll shoot a video and post it up.
Thanks in advance for any input.
Old 03-09-2013, 03:11 PM
nlemerise's Avatar
nlemerise
nlemerise is offline
Sure sounds like the Bendix (or starter drive) on the starter is sticking...You can replace or clean/rebuild the Bendix drive. I haven't had this happen on my truck, but the symptoms are very similar to what I have experienced on other vehicles. I would fix the problem asap though...it can lead to damaged flywheel teeth.
obscurity
15
09-10-2015 04:09 PM
MauleOne
1999 to 2016 Super Duty
09-17-2012 01:31 AM
Greenlawnracing
16
02-28-2010 07:14 PM
ponch37300
15
02-05-2007 02:34 PM
mike L
Electrical Systems/Wiring
12-15-2004 10:31 PM
Quick Reply: Starter acts up on cold days
