Sponsored by: Real Truck
7.3 Starter Problems
Old Sep 14, 2012 | 08:04 PM
MauleOne's Avatar
MauleOne
About two years agao the starter quit working on my 99 F350.
Following this forums advice I had the starter rebuilt by a good shop.
About a year latter the solenoid became intermitent. Some time It would work, some times it wouldn't. Then the relay would just click.
Being away from home base at the time I bought a new unit from NAPA.
Seemed to cure my problem.
Now, about six weeks latter, I am having starter problems again. On the first start on a cold morning (it is getting cold here in Alaska) the starter will grind against the flywheel and not engage. After a coupla tries it works ok and continues to work ok for the rest of the day.
the next morning, if it is cold out side, then it will grind before it engages. If it is not cold outside then it will work normally.
I am again away from home base and have had to order a starter which should be here tomorrow.
I wil borrow something to drive to get to work in the morning. Then I will probably do the starter change in the parking lot where the truck is left over night.
Lets hope it is not raining tomorrow.
so what would make the starter grind against the flywheel when it is cold but work fine when it is warm out?
Will post results.
Old Sep 15, 2012 | 02:41 AM
BigAlsPSD's Avatar
BigAlsPSD
Sounds like either weak batteries, corroded connectors or a weak bendix on the starter itself.
If you wait til after the GP's are off, when it's cold does it still grind?
Old Sep 15, 2012 | 10:56 AM
MauleOne's Avatar
MauleOne
Starter
Only when it is cold.
Batteries are new and seem to check out ok ( I have a digital voltmeter )
To avoid any more damage to the flywheel I will be changing this starter out today.
I agree, it sounds like a solenoid problem.
Old Sep 16, 2012 | 04:57 PM
MauleOne's Avatar
MauleOne
Starter
New NAPA starter installed. Now lets see what happens.
Old Sep 17, 2012 | 01:31 AM
twags6's Avatar
twags6
With everything being so cold, the bendix probably isn't shooting out all the way (grease too thick??) so replacing the starter is the way to go.
Rose Clifford
Mar 9, 2013 03:11 PM
Greenlawnracing
Feb 28, 2010 07:14 PM
RippedF350
Feb 2, 2010 08:37 PM
ponch37300
15
Feb 5, 2007 02:34 PM
mike L
Electrical Systems/Wiring
Dec 15, 2004 10:31 PM
