Sponsored by: Real Truck
Hot wire to trailer
Old Mar 9, 2013 | 02:59 PM
Team roper's Avatar
Team roper
Exclamation Hot wire to trailer
I can't get my interior auxiliary lights to work in my horse trailer. I have a 2012 f350. I've checked the fuses and ran a test light to the hot wire on the plug coming out of the pickup and have no light. Does anyone have a solution thanks
Old Mar 9, 2013 | 04:03 PM
JWC 3's Avatar
JWC 3
I see a lot of trailers wired differently . Are you sure your truck plug matches what your trailer has for aux. ? I see a lot of confusion between brake wiring and aux . Some issues with break away wiring also . Just a thought !
Old Mar 9, 2013 | 04:20 PM
Team roper's Avatar
Team roper
Yes I checked everything and it works I can't figure out why I don't have power coming out of the plug of the pickup
Old Mar 9, 2013 | 04:39 PM
JWC 3's Avatar
JWC 3
A wiring diagram would be a good investment . Perhaps a relay , or fuse is not installed from the factory . I have seen that . Even with factory towing pkg. Last thought , run or jump a new wire to power accy.
Old Mar 9, 2013 | 05:43 PM
dualwheels66's Avatar
dualwheels66
I agree with JWC 3, look for a missing relay under the hood. look in your owners manual to get the relay and fuse locations.
Old Mar 9, 2013 | 06:19 PM
jroberts257's Avatar
jroberts257
locations are here https://www.fleet.ford.com/maintenan...ls/default.asp
Old Mar 9, 2013 | 09:42 PM
rrrrick's Avatar
rrrrick
Just in case....first make sure the ignition key is turned on, then check the relay
Old Mar 9, 2013 | 11:15 PM
r2millers's Avatar
r2millers
I bet you have the most common issue with trailer lights... Poor ground. Complete the circuit before you doing anything else.
Old Mar 10, 2013 | 03:32 AM
Yahiko's Avatar
Yahiko
The Fords unlike everyone else turn the hot lead OFF when the keys are not
turned on. So if you want/need lights to work when the ignition is off your
going to need to install an aux battery.
Sean
Old Mar 10, 2013 | 08:56 AM
Denola's Avatar
Denola
I agree---mine lost power to trailer plug---went to owner's manual---saw there was a relay in the power distribution box under the hood----replaced the relay and solved the problem. Since my winch battery is constantly charged from that wire, I installed a circuit breaker at the plug junction to help it from being overloaded.
Old Mar 10, 2013 | 01:44 PM
GHeTTo JOe's Avatar
GHeTTo JOe
ive seen the missing relay underhood, id check that like has been stated.
idsubgun
Jun 19, 2013 08:07 PM
2006SDpower
Jul 26, 2011 11:51 AM
cdrmotorsports
Sep 1, 2010 09:35 PM
Hometown Pride
All Things Towing
Apr 16, 2007 08:02 PM
Gary E
Dec 4, 2004 12:11 PM
