Help with ball joint brands
Old Mar 9, 2013 | 01:17 PM
PNWguy's Avatar
PNWguy
'78 F250 manual 4x4, Dana 44-9f axle.
I'm having an off-road shop I've used in the past do the install, but I want to order the parts myself to make sure I get the best.
Two questions:
1. Here are two sets I found on RockAuto. Of the two, which would you go with (or should I look for something else?). I'm assuming it's better to stick with same brand for both uppers & lowers but not sure if that's necessary
>RAYBESTOS Part # 5001070 Professional Grade $30ea
Front Upper; Except 4500 Lb Drive Axle; 4WD
>RAYBESTOS Part # 5051156 Professional Grade $31ea
Front Lower; Except 4500 Lb Drive Axle; 4WD
>MOOG Part # K8194T Problem Solver - One of our most popular parts $27ea
Front Upper; Incl. powdered-metal gusher bearing to allow grease to penetrate bearing surfaces; Exc. 4500 lb. Axle; 4WD
>MOOG Part # K8195T Problem Solver - One of our most popular parts $25ea
Front Lower; Incl. powdered-metal gusher bearing to allow grease to penetrate bearing surfaces; Exc. 4500 lb. Axle; 4WD
2. Since I'm ordering and installing b/j's, are there any other related parts/extras I should look into?
Old Mar 9, 2013 | 01:44 PM
dlburch's Avatar
dlburch
when I was doing front end/alignment work I always used Moog if possible...not sure who actually manufactures the parts these days...
Old Mar 9, 2013 | 01:52 PM
montana_highboy's Avatar
montana_highboy
Either one will serve you well, i'm partial to Spicer (now sold under the Raybestos banner).
Old Mar 9, 2013 | 02:13 PM
Beechkid's Avatar
Beechkid
Moog or Motorcraft....Spicer is very good but...much or raybestos is sourced from different suppliers...much of which is chinese junk.
Old Mar 9, 2013 | 03:05 PM
Rob Cuenin's Avatar
Rob Cuenin
I used Moog brand when I did mine because they were greaseable, I think I got them from Advanced auto,almost $50.00 a piece
Old Mar 9, 2013 | 03:18 PM
alchemist1's Avatar
alchemist1
Moog is a tad better, my opinion. Spicer/Dana Chassis (now Raybestos owned - boo hoo) dropped their lifetime warranty and now only has a three year warranty on their premium line. Moog is lifetime. Frankly, I think both Spicer and Moog are chinese made. is there anything that is NOT chinese made?
Old Mar 9, 2013 | 03:44 PM
PNWguy's Avatar
PNWguy
Aren't the Raybestos b/j's greaseable also?
I've heard both good and bad on the newer Moogs, some saying the quality has slipped somewhat over the past few years. ... Man, hard to choose between almost any brands these days with all the Chinese outsourcing going on.
Old Mar 9, 2013 | 05:21 PM
alchemist1's Avatar
alchemist1
Yes. Both Moog and Spicer have the zerk fittings. That can be another matter. I've seen those grease fittings, which always come separately packaged, have lousy threads and strip easily. On some of the AC Delco Performance line of front end parts, the polymer was polyurethane. U would need to use synthetic grease for them.
Old Mar 10, 2013 | 08:27 AM
F-250 WARHORSE's Avatar
F-250 WARHORSE
I have used all kinds of brands, and my experience was the OEM (usually motocraft or spicer) yielded a longer life. We have put autozone valucraft in a f350 powerstroke and they have lasted very well for years or abuse with 35" tires. I have also had no bad luck with autozone's higher line of "DURALAST". Whatever NAPA was selling a few years back was not very good. My orielly has motocraft I think. Good luck.
Old Mar 10, 2013 | 09:51 PM
metalflake's Avatar
metalflake
Motocraft/Spicer have also given me the best service.
Old Mar 10, 2013 | 11:46 PM
fordcrzymike's Avatar
fordcrzymike
I always try to use moog for suspension parts. I think most of their stuff is made in the usa, but i'm not sure whether or not they outsource parts. I will NOT use house brands anymore unless I have to.
green_95
May 12, 2016 01:24 PM
Spktyr
Sep 9, 2012 06:30 PM
bcaughhorn
Aug 21, 2012 11:23 AM
lookin71
Oct 22, 2007 09:52 AM
Chuckzet
1997 - 2003 F150
Sep 14, 2003 07:08 PM
