Sloppy front axle
Old May 12, 2016 | 11:12 AM
green_95's Avatar
green_95
Sloppy front axle
Was under my truck today just inspecting things in preparation for the ball joint and front u joint job I'm getting ready to do when the parts come in. I grabbed the axle on the passenger side where it goes into the spindle on the back side of the tire and shook it and it has a lot of play in it. It just flops around very excessive play. I'm assuming it a bearing that's bad. But which one? I'm trying to have all the parts with me so I can minimize down time.
Old May 12, 2016 | 12:47 PM
Jarrett Campbell's Avatar
Jarrett Campbell
I'm assuming that it's a Dana 50 IFS since you grabbed your axle...
There is a needle bearing that was completely gone in my truck when I took it apart. The axle had a lot of play like you described before I replaced it.
Old May 12, 2016 | 01:07 PM
green_95's Avatar
green_95
It's got a 50 stamped in the differential. So I'm assuming it is a Dana 50.
Old May 12, 2016 | 01:17 PM
Jarrett Campbell
I hope this helps...
The bearing 3423 was the one that had been shredded on mine.
Old May 12, 2016 | 01:24 PM
green_95's Avatar
green_95
That's exactly what I'm thinking. It's the only logical thing that it could be. Gonna run to harbour frieght and pick up a slide hammer. Been wanting one for a whole now I got an ax use to buy one. I just hope it hasn't buggered up the actual axle shaft.
Lukes66
Aug 19, 2014 02:18 PM
97 RED PSD
20
Feb 11, 2008 07:52 PM
Twisted Light
Aug 26, 2007 09:44 PM
ugly88
16
May 30, 2006 09:34 PM
Unimog005
May 27, 2006 10:03 AM
